460 short block question - Ford Truck Enthusiasts Forums
Old 12-16-2014, 10:13 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
I have a friend who used to build marine engines who is helping me with my upgraded engine. Of the two late (D9TE) short blocks, both have bad cranks, beyond fixing. One is warped .040, the other is .060 under as removed. The only other one I have is still in the truck in the 1986 short block.
I have access to an unbored 1977 block, and my friend has a fair stock of standard internally balanced 460 cranks from marine engines.
My question, if I use the 77 block and internally balanced crank, do I need to find the older rods ar can we use the either 1990 or 1993 rods out of the other short blocks?
Old 12-17-2014, 11:59 AM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
Yes you will need to get the older rods. You should measure the deck height. Get the casting number off of the block to verify. There were a couple different deck heights in the pre-D9TE blocks(10.322" deck). I know they were shorter, but not sure how much. Sent from my iPad using IB AutoGroup
Edit: Unless it was the pistons that were different height????
Old 12-17-2014, 01:19 PM
You are correct about the deck height, we are going to deck it probably .020 anyway to get the compression up around 9.2-9.4:1
1979 460 swap questions mightymoose95 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-24-2016 08:45 PM
79 f-150 460 swap mightymoose95 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 01-24-2016 02:32 PM
D0VE block, 2Y cranks, D0OE balancers, rods, caps, carbs, etc vrr Ford Truck Parts for Sale 4 02-24-2015 10:19 AM
Internal vs. External Balance bigdan1979f-250 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 12-07-2011 07:44 PM
76 Lincoln 460 vs. 87 460 ajfriz Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 01-09-2009 11:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
