Need a little help....
Just did the EGR delete and new oil cooler. Oops I screwed up when I took the oil filter housing off I dropped the little spring/valve and did not notice it until yeah you guessed it....I stepped on it..I can only assume that this has happened before and a quick drive to my local ford stealership parts department for a replacement part right?
Finished all the work putting it back together. Starts up but shows no. Oil pressure on the dash which I'm sure is the spring thing because when I put the wrong oil filter cap on that was what it did...if anyone has the part number too that would be great info...thanks for your help...
Joe
Joe
Think this is what you are talking about. Don't think you can get just the spring and valve part, but not positive...
3C3Z-6C755-AA
3C3Z-6C755-AA
No I found is here 2003 FORD F-350 SUPER DUTY Oil Filter Drain Valve[ID],0,ck[idlist],0,ck[viewcurrency],USD,ck[PHP_SESSION_ID],bhrk7151bifc6givg09lsaru84 hope not breaking rules... But this is the part I need..hope stealership has it in the am...
rgreene99
08-22-2012 10:45 PM
Kwikkordead
21
02-25-2005 10:51 PM
