Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Old 12-16-2014, 08:57 PM
4x4junk 4x4junk is offline
4x4junk is starting off with a positive reputation.
Another lift, tire thread.
I just traded an expedition for a 00 excursion 4x4. Always wanted one, it is an extra vehicle so I plan to play with it a little. The plan is to tow a trail rig with it, but I want it capable enough to drag my jeep back to the trailer if it breaks. Only towing 42 miles in rural Kansas, most the way is 55mph. So what are opinions on tire size and lift for a happy medium? I am not afraid of fender trimming in any way. 5.4 with 4.10s, limited slip rear. Not crazy about spending money on a gear swap but not ruling it out. I suppose the smart answer is probably 33s and call it good but that's a long truck to get anywhere on 33s. I would like a d60 swap, gears, detroits, 6 inches an 38-40s but I can't see towing with that.
Old 12-17-2014, 09:10 PM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
I agree Junk, 33"s with the stock 4.10 gears will be about as far as you'll want to push that 5.4 with a loaded trailer. Of course anything is possible, how much of your money can we spend?
__________________
Tom 2005 Excursion XLT V-10 4X4, '04 SD 18"s, Modded X/B's, 35" Nittos, 4.88s.
'08 Mirrors, Hellwig, Ultra-Gauge, Banks Headers, 5 Star Tunes, GlowShifts, Ranchos.
ASPEN GREEN (Jolly Green Giant) Grey Cloth Interior, WeatherTech Mats.
'89 SeaRay 220CC 325HP Mercruiser Alpha, Full Camper Canvas, 11' Achilles 8HP Merc.
'14 Jayco Eagle Premier 338RETS TT, Hensley Arrow, Prodigy P3, TST 507RV TPMS, 61'.
Old 12-18-2014, 11:58 AM
Excursion
I have a 4x2, f250 v10, to tow with, the Ex would only pull about 6k, 42 miles. I would like to go with 35-37's, but not sure I want to if it will be miserable a gear change, or if it will suck to tow on tires that large stability wise. I take it you don't mind the 35's towing trailers? Would you go any larger?
Old 12-18-2014, 12:46 PM
Krazee Matt's Avatar
Krazee Matt Krazee Matt is offline
Leadfoot
Krazee Matt has much to be proud ofKrazee Matt has much to be proud ofKrazee Matt has much to be proud ofKrazee Matt has much to be proud ofKrazee Matt has much to be proud ofKrazee Matt has much to be proud ofKrazee Matt has much to be proud ofKrazee Matt has much to be proud ofKrazee Matt has much to be proud of
Krazee Matt
Quote:
I'm on 4" with 35's, 7.3 and stock 3.73's. Zero issues towing, happy medium all the way around. Obviously taller than stock, without being obnoxiously so or being a PITA to use. 35's are reasonably priced too, pending rim size of course.
You'll find that dingleberry on the transmission likes to hang up on everything. My X sees dirt and trails frequently and the 'berry is bent backwards 90*. Departure angle is a bitch too, ugh. Hitch and tractor hook save me a lot on that end.
__________________
FTEMaB #1
Stay Puft: 2001 Excursion 7.3 Lmtd 4x4 / 6637 intake / 4" turbo back, 5" tips / RR FRx, HPX, billet wheel, triple gauge setup / DP F5 / CT VB code, level, Bilsteins / 315/75/16's
Cecelia: 1971 Chevelle / built 357 SBC / built TH400 / 3k Holeshot / 12-bolt, 3.73's, Detroit
Old 12-18-2014, 06:52 PM
WE3ZS's Avatar
World Famous
I run '04 SuperDuty 18" rims with Nitto Dura Grapplers in 305/70R18E (35.28" tall) and pull a 12k 41' TT, tongue weight is 1400+lbs and rear axle weight when loaded gets over 6500lbs. I have no issues at all with these 35"s but I don't think I would be as happy with 37"s in my situation, at that point sidewall height could become a stability issue.
Could you borrow a set of 35"s to give the loaded trailer a test tow to see how bad the 5.4/4.10 combo might be?
__________________
Old 12-18-2014, 10:37 PM
LivingLarge's Avatar
LivingLarge LivingLarge is offline
LivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputation
Quote:
Originally Posted by WE3ZS View Post
I have no issues at all with these 35"s but I don't think I would be as happy with 37"s in my situation, cause then I would need to use my little stool to get in
There you go Tom, I fixed that for you
__________________
Michael
05 LTD 4x4, PSD, ARP, Tuner, Cat Delete, K&N CAI,4" Exhaust w 6" SS Tip, 5" Lift, air bags & RAS, 35's Terra Grapplers on Fuel Wheels, Bilstein 5100's with Dual stabilizers, Twin air, train horn, Amp Research, Rigid Industries, F&R Mag Hytec, Pioneer Nav, 2010 OEM mirrors, DC 270 amp, Blue spring, much more...02 LTD 4X4, V10 Sold
"I bought a 6.0 PSD and I'm not afraid"
Old 12-19-2014, 01:31 AM
WE3ZS's Avatar
World Famous
Quote:
Attachment 111341
Excellent! I've never had a personalized stepstool before! Now I can get those big 37"s !
__________________
Old 12-19-2014, 03:13 PM
mulepic mulepic is online now
mulepic is starting off with a positive reputation.
I have the 7.3 w/ 35" on 18" wheels. It's a noticeable stability downgrade from the stock wheels/tire size when towing. Also, towing w/ 35" and 3.73 sucks, the Ex can't get to overdrive on the slightest incline. And I'm at 2k rpms doing 75mph which is a little hairy when towing w/ these larger tires. But since you already have 4.10's you might be ok, but I know nothing about the 5.4.
Old 12-19-2014, 03:45 PM
Leadfoot
Krazee Matt
Quote:
What the heck are you towing that it's a downgrade? I just moved 2600+ miles towing close to 9000lbs and didn't have a single issue with anything, and I have more sidewall than you as well. You sure you had the tire pressure set right? Small sidewalls = stiffer sidewalls = increase in stabilty. Towing anything significant when lifted without a swaybar will definitely contribute to adverse stability, not bigger wheels. Tow tune made a nice difference though, so that may be a contributing factor. Only had to use tow on long grades though, it stayed in Eco on flats and worked great. 2000rpm at 75 is about average for 35's on stock gears as well.
__________________
FTEMaB #1
Old 12-19-2014, 04:11 PM
Now you have me curious about the horsepower mods you've made. I'd love to keep my gears if I could figure out how to get more power so I can tow w/ these tires. My TT is only 4000lbs but here in phx you have to go up a hill to get out of here and even the slightest grade I can't get into overdrive.
Old 12-19-2014, 06:18 PM
Rscottc Rscottc is offline
Rscottc is starting off with a positive reputation.
I have had 2- 3/4 ton work trucks in the last 4 years with 5.4Ls, great motors. Towed equipment trailers with no problems,plenty of power and gas mileage averaged about 14mpg, better than my V10 not pulling a trailer.
__________________
2002 Excursion V10 6.8L-magnaflow 3" exhaust,everything else stock for now.
1986 Ford Bronco EB Edition 5.0L-Flowmaster 40s x2
1993 F150 5.0L
2007 Edge AWD
2013 E150 stock
Old 12-20-2014, 12:47 AM
Leadfoot
Krazee Matt
Nothing crazy, typical stuff really... DP F5 chip, 6637 intake, 4" turbo back. That's about it for power mods the rest is just improvements. I went through AZ on my trip, Phoenix and up to Prescott while towing. I'll give you the trip to Prescott was a bitch with the hills in the summer, just watched the trans temp climb uncomfortably close to 220*.
__________________
FTEMaB #1
Old 12-20-2014, 10:52 AM
Quote:
And I'm sure you weren't in overdrive. We climb those hills in the summer when it's 106 out. I think you re-convinced me 4.10 gears are the route for me. I need to keep this thing around and running it cool is key.
Old 12-20-2014, 11:15 AM
Leadfoot
Krazee Matt
Actually once it got rolling and there was some momentum built up it wasn't bad, it only dropped out of OD on the crazy long grades, and I would manually do so myself anyway - the revs need to be over 2000rpm on the engine to keep from lugging the turbo. You can see EGT's drop significantly on long or steep grades. Overheating the engine is a fairly rare occurrence for the 7.3 when things are working properly.
A 6.0L trans cooler is a far cheaper investment that can be had through several vendors on the forums, and at around $350 is the route I would go first. The stock cooler is an absolute joke. I highly recommend swapping one in first before gears.
__________________
FTEMaB #1
Old 12-20-2014, 12:25 PM
Already have the 6.0 cooler. I'll tow a couple more times w/ the 3.73 gears and see how it goes. But I hated how anemic it was compared to before I put the 35's on.
Similar Threads
Axles swap or gear swap? TIUSER Excursion - King of SUVs 40 08-26-2014 05:13 AM
'95 F150 5.0 to 5.8 Swap Questions 1BAD954x4 1987 - 1996 F150 & Larger F-Series Trucks 24 02-06-2014 05:32 AM
setting up my rig quincyj34 1987 - 1996 F150 & Larger F-Series Trucks 2 03-19-2013 05:37 PM
Engine Rpm @70 mph jmmm Ranger & B-Series 8 02-16-2009 05:15 PM
gear ratios slifer Clutch, Transmission, Differential, Axle & Transfer Case 5 11-08-2003 03:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
