1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2002 Navigator, Multiple Codes
Old 12-16-2014, 05:15 PM
pick44's Avatar
pick44
pick44 is offline
History: electrical drain for several years. batter will die after about 1 week if I don't run it. Several times I have had to charge it. Most all others things working okay.
NOW for current issue.
At present, my gas gauge on 2002 navigator does not work. Here's how it started.
1. Start Engine- all gauges working...3 secs later, a muffled sound is heard from under hood ( I think) and all gauges stop working.
2. After about 3 seconds all gauges come back on except gas gauge.
Next day...
1. Start Engine-all gauges working including gas gauge
2. Drive for about 2 minutes and gas gauges stops working
today
1. Start Engine - all gauges work except gas gauge.
Pulled codes: P0460; c1284; B1202; B1313
I cleared codes today and will recheck them tomorrow.
Two auto shops wanted to:
1: First Shop...replace gas sending unit in gas tank $900-$1000
2 Second Shop...too many codes...don't know where to start. But sounds like short in Dashboard cluster. Could cost $900-$1000 to find out and replace.
So, I am here, asking for help.
Thanks
Old 12-16-2014, 06:54 PM
alloro's Avatar
alloro
alloro is offline
Received 4,185 Likes on 2,425 Posts
Change the battery saver relay and see if one or more of the problems clear up.
Old 12-17-2014, 06:36 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Well you do have fault codes for both the fuel sender and the battery saver relay...
Old 12-17-2014, 08:27 AM
pick44's Avatar
pick44
pick44 is offline
I will replace the Battery Saver Relay and also the Instrument Cluster Relay. Will let you know if this works. Thanks
Old 12-17-2014, 03:29 PM
pick44's Avatar
pick44
pick44 is offline
I replaced the Battery Saver Relay and the gas gauge still does not work. I am down to two possibilities and either ones of them is costly.
Either the Instrument Cluster or:
1. Poor electrical connection at the fuel level sending unit or the unit itself is bad.
What I don 't understand, is why did all gauges stop working for 2-3 seconds after I started it a couple days ago and all started working again after a few seconds, except the gas gauge.?
I need some ideas.
Thanks
scottddove
09-21-2015 08:58 AM
SideWinder4.9l
03-05-2011 12:09 PM
usherac21
12-03-2004 08:24 AM
Chopped64
02-24-2004 12:04 AM
eigenvector
1983 - 2012 Ranger & B-Series
02-17-2004 10:32 PM
Quick Reply: 2002 Navigator, Multiple Codes
