48 wiring to get it started /starter removal ?
Old 12-16-2014, 03:37 PM
rustydicksimports's Avatar
rustydicksimports
rustydicksimports is offline
hi
i have a 48 ford f1 all stock
sat in a field for a long time
wiring is shot and all switches shot
starter seized how do i remove it ? i have got all the bolts out that i can see but will not come out have i missed one
also
i think it is 6 volt battery ,how do i hot wire ,to try to start it
can i connect a 12v battery ?
richard
england
thanks for any help guys
Old 12-16-2014, 04:03 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
Originally Posted by rustydicksimports
hi
also
richard
england
First off, Welcome to FTE the best place for advice on working on these old Ford trucks.
To begin, if you have a 'stock' F1, it was equipped with either a flathead 6 or V8, both used the same starter and required the removal of only 2 bolts to remove the starter, they are indicated in the photo below.
The bolts do not need to be removed completely, simply backed out of the bell housing plate. If it's been sitting a long time, you may have to get the motor to turn some or beat and bang a bit to break it free from the flywheel.
To answer your other question, yes you can start it with a 12v and bypass all the old wiring. Make sure you have a coil compatible with 12v, you can hook a temporary 'hot' wire from the battery to the coil (don't hook up until ready to fire up) then ground the battery to the motor and jump the starter from the battery.
Old 12-16-2014, 05:05 PM
rustydicksimports
thanks
hi thanks for the help
Old 12-16-2014, 05:30 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
I've never had the starter off of my 50', but that starter looks alot like the one on my 8N ford tractor, when the two bolts are removed on the tractor starter , the starter falls apart. I hope this is not the case with the truck starter.
Old 12-16-2014, 05:32 PM
rustydicksimports
i will watch out for that
thanks
i will be careful when removing
rich
Old 12-16-2014, 05:45 PM
toby tough's Avatar
toby tough
toby tough is offline
They fall apart if your not careful pulling it out. Have a nut handy to put on one of the bolts once you get it out. Also there should be a strap of sorts from one of the oil pan bolts that helps hold up the end when it's installed. I had a hard time getting brushes for mine at Napa and asked them to check for the 8N. Sure enough ,the same. By the way welcome to FTE. Lots of experienced folks here willing to help. Also the starters don't pull straight out, you have to kinda wiggle it a bit to get the thing out .
Old 12-16-2014, 05:55 PM
Elmo4895's Avatar
Elmo4895
Elmo4895 is offline
The best way to remove the starter on the 8n and the flathead ford is to get two 1/4" nuts and when you back the bolts out of the engine pull the starter out just enough to start the nuts on the starter bolts and run them up finger tight against the starter. Otherwise the starter is easy to come apart and fun to get back together. Also do not turn the bendix after you get it out because it will stick and you have to run the starter on 24 volts to get it to turn fast enough for the bendix to release. I had the starter on my 8n rebuilt and the kid at the shop must have turned it out and put it in a box. I didn't catch it until the next day. I just hooked two twelve volt batteries in series and ran the starter off them. You don't have to run the starter but a few seconds and the bendix will release. Oh yeah put your foot on the starter before you hook it up or it may jump around and disconnect your jumper cables!
Elmo
Old 12-27-2014, 02:00 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I agree with harleymsn but if you replace the starter and you have a V8 the starter bendix pictured above it may not go through the gap between the bell housing and the block. Mine did not and I had to remove the new bendix and install the old one (has the exposed spring) on my new 12v starter.
12V Vintage Torque Starter | Dennis Carpenter Ford Restoration Parts
Or you can order a starter with the correct bendix.
JSPhotographers
18
01-29-2018 11:11 AM
DieselDrake
07-02-2012 04:11 PM
chucky0094
08-31-2008 08:34 PM
Ksnarf
12-28-2005 01:45 AM
theCroch
11-07-2003 09:25 PM
Quick Reply: 48 wiring to get it started /starter removal ?
