Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-16-2014, 04:37 PM
rustydicksimports rustydicksimports is offline
rustydicksimports is starting off with a positive reputation.
48 wiring to get it started /starter removal ?
hi
i have a 48 ford f1 all stock
sat in a field for a long time
wiring is shot and all switches shot
starter seized how do i remove it ? i have got all the bolts out that i can see but will not come out have i missed one
also
i think it is 6 volt battery ,how do i hot wire ,to try to start it
can i connect a 12v battery ?
richard
england
thanks for any help guys
Old 12-16-2014, 05:03 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn has a great reputation on FTE.harleymsn has a great reputation on FTE.harleymsn has a great reputation on FTE.harleymsn has a great reputation on FTE.harleymsn has a great reputation on FTE.
Quote:
Originally Posted by rustydicksimports View Post
hi
also
richard
england
First off, Welcome to FTE the best place for advice on working on these old Ford trucks.
To begin, if you have a 'stock' F1, it was equipped with either a flathead 6 or V8, both used the same starter and required the removal of only 2 bolts to remove the starter, they are indicated in the photo below.
Click the image to open in full size.
The bolts do not need to be removed completely, simply backed out of the bell housing plate. If it's been sitting a long time, you may have to get the motor to turn some or beat and bang a bit to break it free from the flywheel.
To answer your other question, yes you can start it with a 12v and bypass all the old wiring. Make sure you have a coil compatible with 12v, you can hook a temporary 'hot' wire from the battery to the coil (don't hook up until ready to fire up) then ground the battery to the motor and jump the starter from the battery.
__________________
Joe
1950 F5 Stake Truck Flathead 8
2001 F250 XLT 4x4 V10
2009 Pontiac G3 the "roller-skate"
www.fordbonusbuilttrucks.com
Old 12-16-2014, 06:05 PM
thanks
hi thanks for the help
Old 12-16-2014, 06:30 PM
Skalywag Skalywag is online now
Skalywag is starting off with a positive reputation.
I've never had the starter off of my 50', but that starter looks alot like the one on my 8N ford tractor, when the two bolts are removed on the tractor starter , the starter falls apart. I hope this is not the case with the truck starter.
__________________
1950 Ford F1/ Jezebel
(The Other Woman)
Old 12-16-2014, 06:32 PM
i will watch out for that
thanks
i will be careful when removing
rich
Old 12-16-2014, 06:45 PM
toby tough's Avatar
toby tough toby tough is offline
toby tough is starting off with a positive reputation.
They fall apart if your not careful pulling it out. Have a nut handy to put on one of the bolts once you get it out. Also there should be a strap of sorts from one of the oil pan bolts that helps hold up the end when it's installed. I had a hard time getting brushes for mine at Napa and asked them to check for the 8N. Sure enough ,the same. By the way welcome to FTE. Lots of experienced folks here willing to help. Also the starters don't pull straight out, you have to kinda wiggle it a bit to get the thing out .
__________________
48 Ford F4 flat 6/4 spd,dump bed
92 Ford F150XLT 4x4 ,5.0 E4OD
98 Ford F150 XLT 4X4 5.4
Old 12-16-2014, 06:55 PM
Elmo4895's Avatar
Elmo4895 Elmo4895 is offline
Elmo4895 is starting off with a positive reputation.
Quote:
The best way to remove the starter on the 8n and the flathead ford is to get two 1/4" nuts and when you back the bolts out of the engine pull the starter out just enough to start the nuts on the starter bolts and run them up finger tight against the starter. Otherwise the starter is easy to come apart and fun to get back together. Also do not turn the bendix after you get it out because it will stick and you have to run the starter on 24 volts to get it to turn fast enough for the bendix to release. I had the starter on my 8n rebuilt and the kid at the shop must have turned it out and put it in a box. I didn't catch it until the next day. I just hooked two twelve volt batteries in series and ran the starter off them. You don't have to run the starter but a few seconds and the bendix will release. Oh yeah put your foot on the starter before you hook it up or it may jump around and disconnect your jumper cables!
Elmo
__________________
1985 F250 Dually
1954 F 100
Two 1951 8 N tractors
Similar Threads
starting issue fellmcg 6.4L Power Stroke Diesel 7 11-09-2014 07:50 PM
wiring a starters on a 48 f1 oldford54 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 06-28-2014 01:59 AM
Solenoid Wiring Help cynestor Expedition & Navigator 2 02-19-2014 03:58 AM
72 F350 ignition question/wiring wally b 1967 - 1972 F-100 & Larger F-Series Trucks 10 02-09-2014 07:28 AM
'92 Explorer 4.0 won't start 69mustang Explorer, Sport Trac, Mountaineer & Aviator 4 08-02-2004 04:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
