AutoEnginuity Power Balance
Old 12-16-2014, 01:38 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Has anybody successfully run a power balance test with AE?
I have yet to get one to run properly. They always show normal, even if there is a dead skip with one injector.
I sent an e-mail off to AE tech support and we will see what they say. I wonder if there is a way to turn off FICM Compensation using AE?
Old 12-16-2014, 01:54 PM
jsm180's Avatar
jsm180
jsm180 is online now
The only way I can see is to shut off one injector at a time but I'm not sure that would be very accurate. There is no way to shut off FICM comp. with AE.
Old 12-16-2014, 02:37 PM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
I think at present only IDS can turn off compensation.
Old 12-16-2014, 03:36 PM
MisterCMK's Avatar
MisterCMK
Nope, shutting off one injector at a time is not a power balance.
Sent from my Telegraph using IB AutoGroup
MisterCMK's Avatar
MisterCMK
No, snap on and a few others can run a working power balance.
Old 12-16-2014, 04:06 PM
jsm180's Avatar
jsm180
Understood, but that is as close as you can get with AE.
Old 12-16-2014, 04:20 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
Will it pick up an injector that is unplugged during the test?
Old 12-16-2014, 04:28 PM
MisterCMK's Avatar
MisterCMK
Hmmm
I will have to give that a shot sometime.
Here is what they have to say:
Chris,
We can’t turn off the FICM Correction at this time.
As far as the Mode$06 you need to select Generic Powertrain from the bottom of the Vehicle Selection screen, then the results can be viewed.
Old 12-16-2014, 04:59 PM
dannyboy950
I know the older snap-on;geneysIII;scanXL;A&E and Matco can't turn off compensation.
Can't say about snap-on in the last 5 years tho.
Old 12-16-2014, 06:20 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
The V 7.0 Snap-On could not.
I was told when they started to be able to
and can't recall it right now. I think it was
somewhere around V 10.0 I think they are
at V 12.0 or V 13.0 now.
Sean
Old 12-16-2014, 11:46 PM
chetspencer's Avatar
chetspencer
chetspencer is offline
My #8 injector is unplugged. I've been trying to explain to AE that there is a column missing in the chart but the say it's not.
Injector #8 unplugged
Old 12-16-2014, 11:51 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
Do you have a pic of it with injector 4 unplugged? I'd like to see what it shows in the middle of the firing order.
Old 12-16-2014, 11:58 PM
fordf150guy's Avatar
fordf150guy
fordf150guy is offline
Never thought of that but makes sence...if 8's dropping out then where is it supposed to show you? Maybe they're just not motivated to fix it since we've already given them our money...although it is one of the better consumer based scan tools it's sad that one of the most useful functions really doesn't work well at all. Atleast it runs a buzz test helping to narrow down injectors that might be sticking when cold
Old 12-17-2014, 12:01 AM
chetspencer
Sorry I don't maybe someone else can take a moment to pop #4 loose and take a screen shot. My truck is running on 7 cylinders (#8 is dead) so i can't unplug any others.
Old 12-17-2014, 12:06 AM
chetspencer
EXACTLY!!
Does anyone know if the Ford IDS Power Balance test has 8 columns of data?
Quick Reply: AutoEnginuity Power Balance
