AutoEnginuity Power Balance
Has anybody successfully run a power balance test with AE?
I have yet to get one to run properly. They always show normal, even if there is a dead skip with one injector.
I sent an e-mail off to AE tech support and we will see what they say. I wonder if there is a way to turn off FICM Compensation using AE?
Sent from my Telegraph using IB AutoGroup
Hmmm
I will have to give that a shot sometime.
Here is what they have to say:
Chris,
We can’t turn off the FICM Correction at this time.
As far as the Mode$06 you need to select Generic Powertrain from the bottom of the Vehicle Selection screen, then the results can be viewed.
Chris,
Do you have a pic of it with injector 4 unplugged? I'd like to see what it shows in the middle of the firing order.
Never thought of that but makes sence...if 8's dropping out then where is it supposed to show you? Maybe they're just not motivated to fix it since we've already given them our money...although it is one of the better consumer based scan tools it's sad that one of the most useful functions really doesn't work well at all. Atleast it runs a buzz test helping to narrow down injectors that might be sticking when cold
Sorry I don't maybe someone else can take a moment to pop #4 loose and take a screen shot. My truck is running on 7 cylinders (#8 is dead) so i can't unplug any others.
Does anyone know if the Ford IDS Power Balance test has 8 columns of data?
