Junction block?
Do you still have one of the extra junction blocks that you made? I just discovered what this part was in my thread here ( https://www.ford-trucks.com/forums/1...l#post15836071 ) and I'll be needing a replacement. I don't think I can PM here yet, because I'm so new. Let me know!
John
John
I think yours is pretty toasty. If you want my old one, just let me know. Probably $5 would cover postage.
The wiring diag. shows both the fuse and and junction block. My 65's did not have the 'alt' gauge so I installed the circuit using a 25 amp fuse block purchased at the local auto parts store for $6, the 'alt' gauge has worked fine over past 30 + years.
Posting earlier pic's of the fuse block and since cleaned and replaced w/ same fuse block purchased at CARQUEST/Advance Auto parts for $6. 2 terminal 25 amp fuse block.
Thanks, guys.
Not quite out working under the hood just yet, but as I was out installing the rebuilt heater box, and pondering the under-hood work, I saw this terminal on the fender apron. Did a little searching around here, but just to be sure (I've not got out the voltmeter yet), I assume this is just a junction block for these three (make it four) wires? It's looking a little ratty, so before it breaks and shorts everything out, I'd like some insight as to whether I'm right about this thing. Thanks-
Edit: I kept searching other threads until I found the answer; the 3rd wire is the main feed for the body harness.
Last edited by 66v8baby; 02-21-2017 at 01:20 PM. Reason: clarification, found answer
xXANBXx
04-24-2019 05:34 AM
midnightmike
05-03-2010 11:33 PM
