Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-16-2014, 01:49 AM
StinkyGringo StinkyGringo is offline
StinkyGringo is starting off with a positive reputation.
New/Used 77 F-150 Custom
Hello Folks,
I am new to this forum as of today, and look forward to learning from all of you folks on here and contributing where I can. I recently purchased a 77 F-150 Custom w/ 351M, 4wd C6 combo and am in the works of getting it driveable. I have been looking around quite a bit and it seems like everyone has put a great deal of effort into compiling information on this forum. I do have a couple of questions to start out with, and if I am asking something that is common knowledge or is asked a lot please don't hesitate to let me know where I should be looking for this info instead of asking. I am still learning to navigate the site. So, here goes:
1) Does anybody have a picture of their throttle linkage/kickdown linkage setup for a stock intake/carb setup on a 351m? When I got the truck, the kickdown lever was not hooked up to anything, I have since hooked it up to the correct bracket, but there is no return spring on it so it does not come back by itself, is that normal? The last C6 I owned was hooked up to an 82 300 in an F-150, and the setup was a little different and I don't remember.
2) Are the front brake lines supposed to be split off of a T? The previous owner did a little bit of strange looking brake work, and I am trying to sort it out because the front brakes are locking up. I replaced the master cylinder, power booster, calipers, pads, rotors, the rear brakes look brand new no leaky wheel cylinders or anything. I am currently a little suspicious of the proportioning valve, and that will probably be the next thing that gets replaced.
I suppose that should do it for now, and I look forward to hearing from you! Thanks for the opportunity to be part of this forum. By the way, a little bit about my background. I am currently working as a Mechanical Designer, and I was a general automotive mechanic before that. So let me know if you guys need any CAD work done!
Click the image to open in full size.
Thanks,
Nick
The new project.
Old 12-16-2014, 09:51 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to behold
Welcome to FTE.
Dunno about kickdowns.
The front brake lines are not supposed to T. The oem prop valve has a port for each front hard line and one for the rear.
Short beds rock. looks like you got one that has survived without being modded. i'd leave her be until you learn her character cuz every rig is different.
Again, welcome.
__________________
73 F100 SB, 4x4, 390FE, NP435, +4 on 35s, 71 F250 LB, 2wd, 360FE, T-18, 70 F100 LB, 2wd, 360FE-EFI, TKO-500, 76K original miles, 01 F150 SuperCrew Lariat 4x4, 5.4L, 01 PT Cruiser Limited (DD), 71 Pontiac Lemans Sport Convertible, 68 Mustang 200-1v, 65 Mustang 289-4v
Similar Threads
C6 kickdown setup on 7.3 -- Pictures please! jefhuf 1987 - 1996 F150 & Larger F-Series Trucks 0 03-14-2013 11:31 AM
66 F250 Power Brakes and Discs - progress and a few questions nonoodlez 1961 - 1966 F-100 & Larger F-Series Trucks 33 12-20-2012 03:27 PM
c6 Kickdown shaft..How much travel? gliderdad Clutch, Transmission, Differential, Axle & Transfer Case 0 07-14-2010 01:07 PM
Will Not Engage CalebJns 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-09-2010 11:03 AM
C6 Kickdown w/ 460 EFI? DosMas Clutch, Transmission, Differential, Axle & Transfer Case 2 11-12-2007 04:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
