1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Instructions for double din head unit install for 2011?
Old 12-15-2014, 08:28 PM
flyhigh123's Avatar
flyhigh123
flyhigh123 is offline
I have a 2011 Ford XLT. Are there instructions or a guide on how to install a double din head unit? I tried search but didnt come up with anything.
Old 12-15-2014, 09:30 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
this link will at least tell you how to remove the center dash to gain access
https://www.ford-trucks.com/forums/9...2011-f250.html
Old 12-15-2014, 09:50 PM
wbrook_ford's Avatar
wbrook_ford
wbrook_ford is offline
Crutch field was the place I went to get the adaptor, wire harness and instructions for my 03 double din install.
Old 12-15-2014, 10:40 PM
Ltngdrvr's Avatar
Ltngdrvr
Ltngdrvr is online now
Received 3,348 Likes on 1,768 Posts
Not a whole lot to it.
I've had about 5 different ones in and out of my 2012.
Old 12-15-2014, 11:40 PM
flyhigh123's Avatar
flyhigh123
is there anything i need to still use the steering wheel controls?
Old 12-16-2014, 06:16 AM
sammy77's Avatar
sammy77
sammy77 is offline
Yes. You may need something like this:
PAC SWI-RC Steering Wheel Control Adapter Connects your car's steering wheel audio controls to select aftermarket car stereos at Crutchfield.com
Old 12-16-2014, 05:20 PM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
Was looking into a double din with gps is there any out there besides kenwood that are good and wont break the bank. ?
Old 12-16-2014, 06:24 PM
sammy77's Avatar
sammy77
sammy77 is offline
The problem is Kenwood is the only brand using Garmin for the navigation. There are other good units out there, but nothing better than the Kenwood/Garmin combo.
Old 12-16-2014, 06:29 PM
heymrdj's Avatar
heymrdj
heymrdj is offline
This x1000. Real GPS systems use Garmin. One of the things I loved about my 2013 Dodge Dart, Uconnect system uses genuine Garmin maps (with updates available from Garmin).
Old 12-16-2014, 06:33 PM
Hotrod70d's Avatar
Hotrod70d
Thats what if figured. Since pioneer and jensen and a few others are a few hundred cheaper
Old 12-16-2014, 10:12 PM
flyhigh123's Avatar
flyhigh123
i just picked up a generic android based 7" screen. Seems like everything i wanted and i love the android system.
Looking forward to the install.
Old 12-17-2014, 05:10 AM
Hotrod70d's Avatar
Hotrod70d
Oh I believe there's a lot of good radios. Its the gps . I dont want a junk one. I should go to a stereo shop and compare some it would be easier even though im sure ill end up with a kenwood
xmontex4
03-15-2012 09:54 PM
Great Danes
06-08-2009 10:15 PM
stroken
12-06-2007 04:02 PM
goodballs87
2004 - 2008 F150
11-01-2005 09:21 PM
aleahey
Bronco II
08-05-2005 11:24 AM
Quick Reply: Instructions for double din head unit install for 2011?
