Auto 4x4 hubs question, and u-joint question
Let me start with a quick question: the axle on the front of my 2015 F-350. Is it a Dana 60 or Super 60? Are the axle u-joint the 1480 model or something else? Any change between 2011 and 2015?
Next, the hubs question:
Previously, I had the manual hubs, manual 4x4 shifter in my 2012 F-250. This was great - once the hubs were locked in, as long as the front and rear wheels were spinning at the same speed, I could pop in and out of 4-HI anytime I wanted. The process was instant. Now, I have the auto / manual hubs and the electric **** for 4x4. So, I understand what happens in the transfer case (an electric motor changes from 2-Hi to 4-Hi and 4-Lo); but what happens with the hubs? Is vacuum supplied to the hubs which 'suck' the hubs locked or unlocked? Does the physical hub selector move from "auto" to "lock" when you change to 4x4?
Good news, then, about the newer units possibly being more reliable.
Senix, I see you're from Frederick. I went there once for a business trip down to Abicor Binzel, back probably 10 years ago. Nice place, I liked it. I'm from NH, so definitely yes, 4x4 has been used several times already. In the summer, I usually go to a camp a few times which has access via a fire road, so 4x4 would be used there as well. But I get what you're saying, keep the front end nice and free. My folks used to drive full-size Broncos. Those things always ended up with front-end 4x4 issues due to lack of use.
