I'm starting this as a time line of my build. The truck is a 1986 F-350 regular cab 4x4 with a factory dana 60 front end, 4spd overdrive and a 6.9 diesel. The plan is for some engine work and in the end for it to look like it did when it was new.....so here we go!
After I had everything off of the front of the engine an spotted a few oil leaks I have it a good bath with the Hotsey,pulled the oil cooler off and going to rebuild it with genuine International parts.
I rebuilt tge oil cooler this evening. Here are the part numbers from International 1804414C1...o-rings. Two per part number
1807563C1...o-rings. Two per part number
1804377C4...gasket. One per part number
1831665C1...gasket. One per part number
