1990 f350 cc seat swap question
on
you see guys putting the super duty 40/20/40 setup in 'em.they make the cab look a bit overstuffed imo.i imagine a bench would look about the same.there's no need to weld the seats to the floor.just drill what holes you need.the seat belt straps have their devoted mounts and that's what will keep you put in the event of a collision.
on
on
to swap in an idi diesel in place of a gas engine,you need the entire fuel system from tanks or at least tank pickups,with feed and return lines.the radiator support and radiator are much larger and need to be changed.the trans bolt pattern isn't ford.it's navistar and it's specific to the engine so you'll need one of them too.then you've got to mount the engine and trans and make sure you end up with the correct drive shaft length.
you'll also need another battery and much larger cables.don't forget a glow plug system with all it's wiring.
if you can get that much work done in a day........i will hire you to work for me!
if you can get that done in a day........i will hire you to work for me!
I'm not too sure how good my engine is I need to do a compression check. The other turbo idi I'm looking at is already all together with a moose pump and moose injectors so I was thinking it might be easier to avoid all the injection pump and fuel setup. Then while the other engine is out I can fix it up.
dont be a debbie downer! im trying to decide if i would like a idi or a 460 in my 99 f250.
firegod75
12-28-2015 10:22 PM
Dirtdog10304
05-01-2014 07:40 PM
