How to stop ball joint squealing
I can't afford to replace it now and want to quiet the squealing that occurs only when I turn right. A mechanic sprayed something on there about a month ago that caused the squealing to stop for about a week, but don't remember what it was. It's a 2002 S.D.....any ideas?
I tried getting grease in but it's a very tight fit and am not positive if I got enough in (assuming not since it's still squealing). I actually got my grease gun stuck on there for about 10 minutes and finally pulled it off and am reluctant to get it stuck on again. I've seen people online spray WD40 or inject grease through the rubber boot and it stopped the squealing.
Generally no. The joints are grease lubricated, and if they don't have a grease zerk there's no good way to get grease back in there and properly lubricate the joint. You can spray something lighter that will quiet the squeak, but the joint will still wear extremely fast.
Have you checked for end play at the wheel?
I'm assuming (now) that your ball joint has no zerk fitting on it to put grease in it. The sealed ones are basically throw aways once they start making noise. The noise is the 2 parts grinding and striking against each other, instead of riding on a cushion of grease between the parts. Those joints are never meant to ride metal-on-metal. And once they start, they wear out very fast.
There is nothing you can spray or soak into that joint that will take the place of the grease.
When the ball joint fails, it usually (but not always) comes completely apart. This is catastrophically bad, as your suspension and steering are tied together at that point, and when it goes, you lose both. No one, not even a shop can "predict" how long you have before it fails completely. All it can really take is one good, deep, unseen pot hole in the road and that ball joint is bye-bye. When it goes, you will lose control of the truck, and very likely cause an accident.
What we're trying to tell you is that it's just not worth the risk. If you can't afford to fix it now, that is understandable, but please park the truck until you can. It's just not worth careening into oncoming traffic, or jumping a sidewalk and mowing down pedestrians.
Let alone, you can cause much more costly front end component damage as it comes apart and steering linkages bind and bend, and the front tire folds under the truck.
EDITED TO ADD--
And you really should replace both sides. If the one side is making noise, the other side will be following close behind it. When you replace them, get the non-sealed kind, with a zerk fitting in it, so you can put grease in the joints as part of your regular maint on the truck.
EDITED TO ADD--
EDITED TO ADD--
EDITED TO ADD--
