will this work? low voltage disconnect device
Ok i get all that..... except why would I go to the starter solenoid. Doesn't solenoid just get power from the battery. I have heard of this before I'm just trying to make sense of it why/how is that different then the battery
BTW, one other issue in this design, if your radio is power by relays off the switch panel make sure that your memory wire is always kept hot and not connected to a source which is controlled by the disconnect device.
The starter solenoid on the passenger inner fender is a handy spot to pick up full time 12 volts. That's what Ford does on your truck already. Or at least I think it does. You've not indicated a year, model, or engine, so I'm only guessing. The idea is to get power direct from the battery instead iof down stream where you will start experiencing voltage drop.
Yes, if there is no delay programmed in, the loads will be disconnected while cranking. I would ask the seller about that. Their website has a contact page here Peak DBI, Quality 4x4 Products and Accessories, Contact - Peak DBI. Other than that issue, based upon the description, this seems to be a very well designed unit for a very reasonable price.
And i didn't think about the memory wire... i think maybe the music devices im looking at dont have a memory wire ....im thinking about buying the ... mc470b... from this website check them out tell me what you think ..... my other idea was an amp and wake board tower speakers
http://www.bossaudio.com/marine-products/utv/
Happy to help. Please post back on this thread after you hear back from Peak DBi regarding the delay. I'm curious myself, and future folks that find this via search also might want to know.
Ok, now I understand the question. I think it's just to keep the battery from being cluttered up. There is already a number of lugs on the battery post of the solenoid to it seems like a logical place to put one more. It's also generally easier and more secure than trying to tuck it under the battery clamp bolt.
The MC470B setup look like an interesting option. Although I would take their claim of 1,000 watts with a grain of salt. Ok, make that a mountain of salt, especially at their claimed 0.01% distortion. If you get 50 or possibly 100 watts of reasonable quality sound it would be more realistic. But picking weatherproof speakers is a good thing. It's a lot cheaper than doing an amp with wakeboard speakers would be.
If you haven't concluded this already, here's what I would suggest.
At least one deep cycle battery, the unit you are planning to install, and a solenoid similar to your starter solenoid but one that is designed to be used for long periods of time. I forgot what they call those but they have them.
Hook your amps to the solenoid out, and the solenoid to the deep cycle battery. Then take the switch to turn the solenoid on and hook it to the delay unit. You'll then never have to worry about a dead starting battery or overloading the units amperage rating.
raytasch
11-02-2013 06:41 PM
Narwhal
05-13-2006 07:22 PM
