I have a 1996 econoline 250 and i am trying to change the water pump and thermostat. I can not get the bolts off of the thermostat cover and also the fan pully has 4 bolts on it and it keep moving every time i got to lossen it . Any help on how to do this.. i am in need of help everything is still apart.
are the belts still on ?
if so , put tension on the belts so the friction stops the pulley from turning
soak all in liquid wrench also
Yes belt is still on. Okay so i put thr liquid wrench on and i have it sitting over night . And how could i put tension on the belt because i am trying to hold it and it slips right out of my hands. Is there any place i should hold it.
Liquid wrench is good, PB blaster, Kroil, etc. Some swear by transmission fluid and acetone mixed 50/50. Also like to shock the bolts with hammer, or use a propane torch and get them toasty. Give the penetrant time to work, reapply and let set overnight seems to help.
typically , I just use my hand and squeeze the belt together at the alternator .
A piece of flat steel , pry bar ... holding 2 bolts will lock the fan to break the nuts loose . Place in front of one behind the next . You now have a lever . You can move the world ......
you may need air tools.
hand jobbing isn't working
Been watching this thread a few days, also wondered why an impact wasn't used? Instead of being too much a lever and easily overcoming whatever force is trying to hold the outer diameter of the pulley an impact puts its energy into torque on the actual bolt.
If this is a 351w good luck. This isn't the hard the hard part is going to be getting the broken bolts out. Then getting everything to seal back up. Might as well buy a new t-stat housing now. Going to need a new water pump bolt kit too.
