My uncle's 53
Thanks' Abe, I was thinking of welding the throttle and choke holes shut.
I spent Saturday morning roaming around a couple bone yards looking for a 9" rear axle, I didn't find one that was any good. I remember 57-72 trucks being a dime a dozen now I can find only a hand full. I did get the leaf springs cleaned up and reassembled. Last night my son came over and helped put the front axle together and install the disc brakes.
Looking good, lfed. Great project.
Something you might want to look at is the rear transmission mount. The original served three purposes. 1) It kept the frame from twisting at the front spring rear mount. 2) It held up the rear of the engine/transmission. 3) It kept the frame from twisting (spreading) at the front cab mounts. 1 and 2 might be alright, but I would be concerned with 3. I would install some bracing, much like the original.
If I'm speaking out of place, I apologize. I just thought it was something worth mentioning.
I like a truck with history. Mine belonged to my uncle as well. But to him it was just an old farm truck. I've had it since I was a teenager and it's in it's 3rd (and final) evolution.
here's a couple pictures, Do you have any ideas?
Your frame looks good, you feel like your getting somewhere when you start painting.
If you use an alloy intake and headers instead of the cast stuff you could get the weight pretty close to the original flatty, they were by no means a light engine. I'd hazard the C-6 would add more weight than the BBF. That weight would be low and behind the firewall, all good.
53 was a good year for new Ford trucks (and new owners for Ford trucks).
Thanks' Harrier.
I started this thread so that my aunt can see how the truck coming along and get the input from FTE members. This truck is a little before my time, that makes harder to put back together two step forward four step back but I'm getting there. Waiting on frame parts so it's back to working on the cab. My goal is to have a rolling frame and the cab and doors painted by the end of winter.
#28
It's been a couple of weeks since I posted anything but I have been working on the cab. I have gone as far as I can go, waiting on a inter cowl piece, Mid fifty said that the part will not be available until sometime in February ( I do not like waiting ). However I did find a Rear axle. I have taken that apart and took it to the powder coaters and I got that back yesterday time to put it back together.
#29
#30
I received my inter cowl piece a couple weeks ago the part isn't even close to the original part, as you can see by the pictures. I end up making my own. Now that I got the cowls repaired it is time to move on to the floor, I had to reposition the cab on the rotisserie so that I could repair the cab mount. I think I'm done welding, grinding and sandblasting. Next is epoxy and paint.
