How "rare" is your F150?
What I was getting at was I never knew you could factory order the 4.09 front/4.10 rear gear ratios for a 1990's V8 4x4 F-150 automatic or manual transmission.
Either Phonemans Ford had a V8 with automatic like John's or possibly was a 4.9L (6 cyl.) engine equipped truck with manual transmission; or possibly (which I've never known) Ford offered those numerically higher gears (4.09/4.10) with the 5.0L and manual transmission equipped 4x4 F-150's as an option. How sweet would that be for wheeling...
Cheers D
The front limited slip was only permitted with 3.54 front axle ratio and only with manual front hubs. This is the reason that the original owner of my truck didnt order it on my truck-he wanted the 4.09/4.10LS gearing to pull his horse trailer.
I looked at dozens of F150s of this vintage-I wanted front limited slip-couldn't ever find one! A three digit code, on the VIN sticker,under "axle", will signify a front limited slip-I believe it is "2xx"-if I remember correctly .
Since the OP lives in Cali-I suspect that he hasn't driven this front limited slip in snow. It would make a difference in traction-I bet!
I've never driven a limited slip front in snow, but I've driven a truck with front and rear automatic lockers. A locker in the rear is OK, but in the front is scary dangerous on snowy freeways. When one front tire loses traction (like when it hits the snow between lanes as you are changing lanes) you get VIOLENT torque steer toward that tire. All of the power goes to the front tire that has traction and it tries to pivot around the ball joints, whipping the steering wheel over pretty hard. The first time I changed lanes like that the truck SUDDENLY moved over 10 feet before I could catch it (luckily I wanted to make that lane change!). The second time I was ready for it and it only jumped over about 5 feet. I shifted out of 4WD and had the locker removed as soon as I could!
A limited slip would do the same thing, but to a limited extent. Limited slips won't put all of the power to the side with traction like a locker will. They'll still put more power to that side than an open diff (that puts all of the power to the slipping tire) so they'll still pull some. How hard they'll pull will depend on how aggressively they are set up.
Great explanation Bob. I've often wondered how the design and physics of a 4WD work when driving in the snow...particularly on freeways like you described. I've had that torque pull when changing lanes. I guess we get used to it after a while, but the feeling of unpredictability is always there.
I know that a locker is the harshest, but after my experience with that I'll never have anything other than an open diff (or a selectable locker that's open when unlocked) in the front axle of a truck I expect to drive at any speed in 4WD. I could maybe see going a different route in a dedicated rock crawler or mudder. But even there I think I'd go with a selectable locker.
Interesting. As mentioned earlier in this thread, this truck has been in snow every year since new; granted it's only for a week or two at a time. I do notice a "wheel hop" during slow speed turns, particularly when nearing the max of each turn to the lock. I've always considered this normal when in 4WD. Otherwise, I have nothing to compare the handling to...this is the only 4WD truck I've driven in the snow. Seems all good to me.
I missed the posting of yours stating that the truck had been in snow. The wheel hop that you refer to in the above post-is that on snow ? Is this wheel hop felt in the steering wheel? Does the truck tend to understeer (make turns wider than desired) when making turns in 4x4 in snow and other low traction surfaces ?
The hop is not really felt in the steering wheel so much. There is a some predictable understeer when turning slowly in snow and 4x4. It's always been a handling feature that I've learned to deal with. Seems normal to me. But then again, I haven't much to compare it with...other than driving a 2WD car with chains.
Originally Posted by Cruise Mansfield
I dont know how rare this truck is i bought its a 2006 ford fx4 stepside with a small rear back window but no seats in the rear. If you know can you tell me thanks im new just joined the forum. My stupid mac computer wont let me upload it either.
Curated Content Editor
2015 - 2020 F150
19
03-06-2019 08:08 PM
Supercoltsfan
10-06-2018 11:40 AM
