Fixed oil cooler o-rings today. What a pain!!!
Old 12-16-2014, 06:11 AM
Tugly's Avatar
Tugly
Tugly is offline
Originally Posted by truckeemtnfords
The best advice I can provide is use a long extension and a swivel socket and the front bolts can accessed from through the wheel well....
This is what I did... with a cordless impact wrench and a looooong extension. I remember it working for one or two, but not all. I can't remember if there are 2 or 3 bolts up there.
I'm glad you're seeing good early results, I'm hoping you nailed it the first time.
Old 12-16-2014, 10:52 AM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Originally Posted by HH60FE
Todd, did ya get your coolent filter replaced?
I did finally. It was stuck good. I used a piece of 3/16 steel rod to put through the filter mount and cranked on the filter with a strap wrench. The new one is on only hand tight but it's not leaking so good to go.
Now I gotta flush my power steering system again though because my cap keeps coming off randomly.
Old 12-16-2014, 01:26 PM
cj45lc's Avatar
cj45lc
cj45lc is offline
Originally Posted by KJNDIVER
1. I didnt see that video.
2. I had a hard enough time pressing it back together with the new orings while it was on a table, no way i could have pressed it together while under the truck.
3. It would **** me off to no end to complete it that way only for the front to start leaking a week after i did all the initial work....
Just greased every thing up good & used a pry bar against the exhaust manifold. It was a nice straight shot & to be honest I was really surprised by how easy the tube slid right into the header, just a little leverage goes a long way LOL
Old 12-16-2014, 02:45 PM
Tugly's Avatar
Tugly
Tugly is offline
In my case, the forward gasket was shot. I had to pull the front off anyway.
Old 12-16-2014, 03:27 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
I talked to a guy at work that tried the YouTube method. He used a porter power to try and get it back together. Broke the front piece and his front cover on the truck. I am glad it went well for me.
Old 12-16-2014, 03:53 PM
andym's Avatar
andym
andym is offline
I used a floor jack, a ratchet strap, and some scrap wood to push it back together. It worked pretty well but I'd much rather have a real press.
Old 12-16-2014, 04:48 PM
Firefighter 1406
I lucked out on my press. Went to buy it at harbor freight, they were out of the 20 ton press. I asked about the floor model. It was missing the plates. They told me they would sell it to me and order me plates. It was on sale and after the discount for being a floor model I ended up getting it for $110. So that is the only reason I have a shop press.
Old 12-16-2014, 07:42 PM
cj45lc's Avatar
cj45lc
cj45lc is offline
I hear ya, glad it went well for you
Porta-Power + Aluminium = Here's your sign LOL
Old 12-16-2014, 09:33 PM
Firefighter 1406
That's kinda what I thought. This guy is a be en there done that type. Even though he calls me with 7.3 questions and to use my a&e all the time. Enough said. You catch my drift.
Old 12-17-2014, 08:08 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
I've never done mine yet but its coming because I see a lot of wetness on the front side of the cooler on both my 7.3's. I thought I would try using a small floor jack and turning my hitch receiver up and use that as a portable press and pushing up on the receiver with the cooler in between.
Old 12-17-2014, 09:37 AM
cj45lc's Avatar
cj45lc
cj45lc is offline
hahahaha
Old 12-17-2014, 12:29 PM
andym's Avatar
andym
andym is offline
That would work too. The truck is surely heavy enough.
  #28
Old 12-17-2014, 09:46 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
I hand pushed mine together. I lubed the o-rings with silicone plumbing valve lubricant.
  #29
Old 12-18-2014, 10:00 AM
andym's Avatar
andym
andym is offline
Where did you get your o-rings from?
  #30
Old 12-22-2014, 11:16 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i think we might have to tackle this in the spring if it holds of, looks like our oil coole is wet some and i seen a few drips of coolant on the ice under the excursion. is riff raff the go to source for the good oring kit?
Quick Reply: Fixed oil cooler o-rings today. What a pain!!!
