IMO, 1/2 tons are swappy. My truck has 3600# rear springs and doesn't really apply. Less than 3600# springs on a half ton can benefit from front and rear sway bars.
I have a front sway bar from a '78 F-250 CS to put on my '69 F-100.
I'm trying to find a Dentside rear sway bar from an F-150 pickup or an F-150 Bronco, for a 9-inch rear end. I know the rear frame rails are 4" wider (2" per side) but, I think I could make it work.
The Dentside/Bronco rear sway bar looks like this.
Which ever Ford truck sway bar you get will probably have to be mounted under the rear housing to clear the shocks and make up some links.
I have one from a 250 Camper Special and that was the only way it would fit. Good luck
