Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-14-2014, 05:21 PM
ved0303 ved0303 is offline
ved0303 is starting off with a positive reputation.
what are the different pins on the voltage regulator?
The alternator voltage regulator has 4 pins; I, A+, S, and F. Does anyone know what each pin does or what it is for?
Old 12-15-2014, 09:00 PM
march's Avatar
march march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
Two different set ups are possible.
Dash idiot light
"F" (alternator field coil)
"S" (alternator stator)
"A+" (battery feed)
"I" (Charge indicator)
Ammeter
"S" (battery voltage with key on)
"A+" (battery feed)
"I" (not used)
__________________
78 F250 SC 4X4 460 C6 NP205 35's
Old 12-16-2014, 10:50 AM
awesome thank you!
Similar Threads
Generator Regulator Tedster9 1961 - 1966 F-100 & Larger F-Series Trucks 7 02-12-2014 06:14 AM
1971 instrument cluster zaqwsx 1967 - 1972 F-100 & Larger F-Series Trucks 0 03-15-2011 05:09 PM
Voltage regulator pinout grams72 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-01-2010 11:48 AM
Pulse Vacuum Hub Solenoid Valve Testing c04678 6.0L Power Stroke Diesel 1 11-11-2009 03:25 PM
MAP Sensor testing. blu beast 1987 - 1996 F150 & Larger F-Series Trucks 6 11-14-2007 07:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
