CCV re-route follow-up
Hi guys,
I did a CCV re-route about 3 yrs ago. I used the Racor 4500 filter and routed the filtered air back into the intake system.
So I was just in checking all of this out doing my standpipes and dummy plugs yesterday.
The upshot is I was very disappointed. Main trouble is there was still some oil in the turbo and in the passenger side CAC tube. It really was not that much better than before installing the re-route.
Additionally, some of the hose fittings had wiggled loose and oil was leaking everywhere - the valve cover and left side of the engine were a mess. I think the extra hoses were in the way when I had the Regulated Return installed. When I put it on, the hose fittings were as tight as I could turn the clamps. But the whole thing is hiding under the degas bottle so it was hard to see.
Anyway I decided to go back to stock. The oil on the driveway was annoying. When I had to change the FICM, those extra hoses made the job a royal PITA. I was about to drain the coolant b/c I could not get the degas bottle out of the way with those damn hoses in there. I suppose I could have gone for the more simple hose down to the exhaust.
SO my feeling is the CCV mod may not really be worth the bother. As the truck gets older, getting in and out of it become more important. It is easy enough to clean up some oil in the intake/turbo.
Thanks guys - good to hear. I thought I would get chastised for this. To me this is one of those things that make lots of sense on paper and not so much in reality. One less filter to change as well.
BTW, if someone wants to pay shipping, I send my set-up to you. I just put a new filter in. I hate throwing things out but the garage is becoming a mess of truck parts.
Add 2nd CCV Line
I put a second CCV line on my motor vice re-routing the original. That way both sides of the motor could breathe at the same time. Used a straight 1/2" brass hose fitting for the oil fill tube, a 90° plastic fitting for the line between the CAI and the turbo and connected the two with a piece of 1/2" heater hose.
Ed
Ed
My main disappointment was that even with the filter on there, there was still some oil finding its way back into the intake. Your method is the better way to do it. I would have to get someone to weld a plug for the intake though.
yeah I was out taking a look at that last night and realized it is plastic (the intake hole), but I am still not sure the best way to plug it. Did you leave the elbow from the CCV hose in there and put the cap on over that? Did you use Blue glue for that? I worry about that opening allowing junk in the turbo.
Do you fabricate some type of ventuie. Avg exhaust pressure by manual gauge test is about 12.psi. CCV vent by manomometer is seldom over 4 psi.
Would not this actually blow exhaust gas back into the crank case?
Just asking????? The ole mans mind is a little foggy today.
Hi guys,
Did you clean out the tubes & cac after doing the vent reroute? How else could the oil get out if you didn't? If you did clean it out how could it get back in there?
