Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-14-2014, 12:05 PM
Smirks90's Avatar
Smirks90 Smirks90 is offline
Smirks90 is starting off with a positive reputation.
Mystery wires on a mystery switch
so i have decided to change out a lot of the old wires in my truck and re run new ones. everything is back together. only a few issues. when i turn on my right blinker all the running lights flash. i think that is just a matter of tracing out which wire is not in the right place. but then there is the switch that is at the bottom of the steering column by the pedals. the switch changes position when you shift through park, reverse neutral and drive. there are 4 wires going to it and only 2 of them are hooked up. what is this switch for and what does it tie into. any ideas? thanks
Old 12-14-2014, 12:15 PM
willowbilly3 willowbilly3 is online now
willowbilly3 is gaining momentum as a positive member of FTE.
Sounds like something wired wrong on the lights, feedback going on. I have actually seen that happen from a burned out bulb when one element touched the other. The switch you speak of is the neutral start and backup light switch. If the neutral start is functioning then the back up lights are not plugged in.
Unless you've been attacking the under dash wiring, I'd start from the back of the truck because of old trailer wiring, pertified wires and repairs in that area, it is most often the cause of malfunctions will begin in that area.
__________________
In the beautiful Black Hills
Old 12-14-2014, 08:20 PM
Smirks90's Avatar
Ok so I figured it out. The bad blinker issue was terrible wiring done by the previous owner that fed the tail lights. The other issue was the backup light switch was not engaging. I took that switch apart and rebuilt it now everything is working as it should. Thank you for your advise.
Old 12-14-2014, 08:57 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The NSS (Neutral Safety Switch) is located towards the bottom of the steering column, also controls the backup lamps. It's the same, 1967/77 F100/350: C7TZ-7A247-A (Motorcraft SW-600).
The NSS selector lever (D0TZ-7B097-B replaced C5TZ-7B097-A) fits onto the shift tube thru a hole in the steering column shroud, its knife blade end fits into the NSS
What happens to it: It loses tensile strength and falls off the tube, or its knife blade end snaps off. When either occurs, the truck can be started in any gear. Not pleasant!
The selector lever is the same 1965/77 F100/350, it's obsolete, but 100's are available NOS
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Similar Threads
Reverse Lights Switch Location Vaokie1 1973 - 1979 F-100 & Larger F-Series Trucks 36 01-31-2014 04:29 AM
Found some interesting wiring, any ideas? bones0351 Super Duty & Heavy Duty 3 09-12-2012 09:15 AM
Dome light short - '75 F-250 Paul49 1973 - 1979 F-100 & Larger F-Series Trucks 11 05-29-2011 11:45 AM
1989 Ford; mystery electrical problem WINGNUT- 1987 - 1996 F150 & Larger F-Series Trucks 13 11-26-2010 09:07 AM
1977 f100 mystery AC harness plug Mikestrucks Cooling, Heating, Ventilation & A/C 2 05-30-2006 05:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
