Starts Runs then Slows Dies!
Put in some kleen diesel booter and helped out quite a bit. Got home and is missing bad. Going to try the ATF trick with a new fliter and let it sit. Now iam affraid it might have caused a malfunction with the fuel pump or IP. See how she does after if not the tank's comming back out. Got to go back to ol'faithful for a date tomorrow since the beast is out for now
Well we tried the ATF trick with only little help to it ran for about an hour good but back to the same result of a either pluged filter. We pressed the relief valve in the top side of filter little pressue. Thinking it might be the fuel pump that got messed up from the sugar being in their
Received 3,090 Likes
on
New lift pump. No help. Drained tank and diesel doesn't have the normal oder or color. Its a very dark brown looks like HYD fluid cant see to bottom. The smell of it burns rather then the usual diesel smell. Put it in some buckets to set over night see what it looks like in the morning and drop the tank. My dad is figuring from the smell and odd color that antifreeze was put in.
You might actually have the water/AF settle out, and be able to pour any usable diesel off the top; water is heavier than diesel(which also means that when you're driving and pulling fuel from the tank, you get the water first).
In that case, you should be fine; Once you get the 'water' out of the lines, and have diesel through the IP, it should run just fine.
One thought though... If you're worried about this happening again, hook up a Tee and shut-off valves just before the lift pump, and keep a few feet of hose and a jerry can of fuel in the truck. Problems? Just shut off the valve from the lift pump to tank and open the other leg; run a hose from that into a jerry can and strap it to the front.
Problem solved, enough to get home anyway.
Alright guys we got her to run flushed all the lines. The diesel that came out had sugar suspended in it. Took a little bit to turn on but started. With one kink that keeps worring me is that when it cranks. It turns on runs and then just dies. I have to crank it for awhile to turn it back on and keep my foot on the pedel 1500 for 30sec to keep it on and runs like nothing after. Just need this last little thing. Dont know if iam losing pressue or something.
This prevents fuel from draining back to the tank, solving the problem. And you can always use it to prime the system if you ever need to.
The transfer pump must have a check-valve in it too, but they rarely work perfectly enough to prevent draindown over a matter of hours.
on
my bet is the sugar got into one of the check valves and is hanging it open, or it messed up something in the return line system letting air in.
#30
on
