Firewall insulation - Cummins Swap - Ford Truck Enthusiasts Forums
Old 12-14-2014, 09:32 AM
79Supercab's Avatar
79Supercab 79Supercab is offline
79Supercab is starting off with a positive reputation.
While the motor is out would it be beneficial to cover the firewall with some sound deadening or heat resistant material?
Cover the hole thing and down to where it starts going back to the floor?
How's it for keeping moisture? I'd hate to get moisture under it and have it rot the metal.
Old 12-18-2014, 12:34 AM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
They make specific heat shield material from dynamat and similar companys. If you prep the firewall properly and use a roller and tape off the seams I see no real way for moisture to sit behind the insulation.
As a side note I insulated the inside of my cab heavily so I do not think having insulation on the firewall would make that big of a difference. I think the biggest path for sound is from the hood in through the windshield. One of the things on my list to do is insulate my hood.
http://www.quietride.com/catalogpdfs...ood_covers.pdf
Old 12-18-2014, 07:14 AM
79Supercab's Avatar
Good info. Those hood blankets aren't too expensive.
Old 12-18-2014, 03:27 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
I insulated the firewall of my 70 Chevelle and it made a difference. So I would guess it would help.
Old 12-28-2014, 06:46 PM
oddfordjunkie oddfordjunkie is offline
oddfordjunkie is gaining momentum as a positive member of FTE.
My biggest source of noise is the trans tunnel from the ZF5, pretty typical for that tranny.
A lot of people make their own "Lizard Skin" sound deadener with latex paint and styrofoam beads, something to look into, Teds74ford did that on his Dodge crew and I believe on his 78 Ford Crew so he could point you out on how to do it.
Every once in a while I come across a factory uner hood insulation at the junkyards or Kit may have one in his private junkyard. haha
Old 12-28-2014, 07:12 PM
79Supercab's Avatar
Quote:
I should have taken that one out of that green SCS I sold
Old 12-28-2014, 09:49 PM
Should have let me swap distributors and a few other things off of it, there's always more.
You still have the Bronco? There may be some helpful items that a prospective buyer wouldn't even realize is missing on that.
Old 12-28-2014, 11:17 PM
79Supercab's Avatar
Should have just swapped the 460 into my crewcab. But that would have put off the cummins swap.
I do still have the Bronco. It's my daily driver now while the crew is down. There's not much to rob off it. You can have all vacuum/smog crap I'm going to take off it
Old 12-29-2014, 01:10 AM
Haha, I was referring to little things most Broncos have like the center hood support, hood hinge reinforcement plates and things of that nature. Things most guys don't even notice that are nice little upgrades.
Old 12-29-2014, 07:54 AM
79Supercab's Avatar
Gotcha. I was thinking the same thing, to swap those little things over to the crew
Let me know if you find one of those under hood insulation blankets at a yard.
Old 12-29-2014, 10:36 AM
Will snag it if I do, they're just a pain to transport without destroying, but I'll be back in my CC shortly and can throw it in the rear of the cab in that.
Concerning insulation, this was the first layer on my floor, am now using Rufco instead of the Vycor.
You can see the Rufco Shield product on the back wall and part of the reason I am and will be sound deadening the $#!T out of my truck, that and I wish to be able to have a quiet conversation driving down the freeway.
Old 01-01-2015, 11:53 AM
merc460 merc460 is offline
merc460 is starting off with a positive reputation.
Phoenix Gold Outlaw! Nice I used to have one of those , great amps.
Old 01-01-2015, 01:41 PM
Quote:
Ehh, I really haven't been impressed with it. My Audio guy put it in as my "Temporary, Entry level" amp and it's coming out in order to go in his private Museum/Display room.
Everything in my truck is temporary, which is why I haven't sound deadened as much as I'd like since I will be replacing my entire floor and building my own tunnel, the tunnel will be double layered and foam filled. There is a LONG list of things before that happens but it'll get there.
Another thing I've considered is using Pour Foam in the lowest 8" of the Pillars and Rockers as it's all dead air space and amplifies the "tin-ee" echo when closing the doors.
Old 01-03-2015, 09:18 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
I have done a bunch of sound deadening, but can't tell you specifically of it's great results-neither truck is finished What I can tell you is that either peal and seal or homemade lizardskin definitely dull the tinniness of the metal. In my experience, the stick on stuff is better at this (probably because it is thicker)
I was paranoid, so I used contact adhesive to stick my peal and seal on. It has never come loose, even on the roof. I think either is good, but I think I lean towards the peal and seal. That being said, I went with the homemade lizardskin so I could coat the entire interior and have it look somewhat like a vinyl and plastic covering while providing some insulation as well. The biggest problem I have in my ford is that there are a lot of wind whistles, so I can't accurately gauge how the insulation is. Hope this helps.
Old 01-04-2015, 02:18 AM
I'm driven to get my truck quiet, so, why not do the "lizard skin" or peel-n-seal then put the hood insulator on?
Concerning installing peel-n-seal I usually use a handheld propane torch to warm the sheet metal, just enough to watch the moisture "run" out/off of the steel. This just makes it warm to the touch, not hot as I don't want to use enough heat to fatigue the metal. This has proved to secure a very good bond.
Since the subject of wind noise got brought up: I have installed both a Lund cab visor and gutter mount KC light bar with 5 lights on it and had no increase in wind noise.
Have tried multiple Decibel Meter Apps on my phone and all of them have had wild variations in readings. Keep hounding my Audio guy to purchase a good one but not many of us have money for extra trinkets like that. haha
2003 e350 moisture under floor mat 60cetane 1968-2013 Full Size Vans 1 12-19-2016 09:05 AM
Moisture in tail light elee3 6.7L Power Stroke Diesel 12 04-01-2016 12:49 AM
1994 F150 - Cab Leak Demonhawk 1987 - 1996 F150 & Larger F-Series Trucks 18 11-13-2015 08:58 PM
Firewall cover question sleddog60 1967 - 1972 F-100 & Larger F-Series Trucks 2 01-07-2015 09:30 AM
Moisture problems in engine JRitt 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-29-2014 07:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
