Need help troubleshooting intermittent powerloss.
Less intermittent as time goes by..
The first time 60 days ago I was going up a grade and had about 75 miles left on one tank and the other was very low. The truck started sputtering like it was out of fuel so I did a U-turn and filled up both tanks. Problem went away for 10 days and again, going up hill it started sputtering. I pulled off to the side of the freeway for a minute and took off without a problem for 10 days. Then soon after that the same two hills have always caused a recurrence.
Changed the fuel filter and no difference.
I took it to my trusted and very good mechanic and he tested everything and found no problems. He suggested tank delamination so I switched to the other tank and went on. Same problem with both tanks.
Next he suggested that I remove my four position chip. I did that and the problem went away going up the grade on the hwy but on the same hill that the problem started on it lost power and could only hit 45MPH. With the chip installed it would max out at 25MPH.
What's next to look at?
TIA,
Vince
TIA,
Vince
As far as the FPR screen, if I remember right it on the inside of the fuel bowl on the drivers side. I've had electric fuel so long I forget the procedure but some say take a Q tip without the cotton on it a scrape it clean.
Riffraff has IPR's and I bought one from TerminatorEngineering once.
