Coil question
Exactly. High secondary resistance is the most likely cause of coil failure, though not the only one.
Yes but the damage was probably done before.
On these old trucks, it's a good idea to check the resistor wire from the switch. Many times it's been scabbed into or butchered. You can still get new ones. I got one a couple years ago from NAPA for my roadster because I hate those problematic porcelain ones and wanted to keep my original 1963 coil.
B6A-12029-B .. Ignition Coil (Motorcraft DG-5).
All 1956/73 & 1974/75 I-6 & V8 without DuraSpark electronic ignition.
1974's with DuraSpark use a different coil, same coil used on 1975 F100/350 before serial number W00,001: D5PZ-12029-A (Motorcraft DG-313-A).
1975 F100/350 from serial number W00,001, 1976/87 all use a different coil: D5AZ-12029-A (Motorcraft DG-314).
headtube
08-07-2017 09:21 PM
peka
34
05-20-2015 01:20 PM
LFDavidson
09-29-2009 08:26 PM
