Hard Cold Start with AE Logs
Old 12-15-2014, 06:56 AM
Hussler's Avatar
Hussler
Hussler is offline
When measuring glow plugs use either engine ground or battery ground and measure each of the two outside pins on the valve cover connector. Each outside pin is a glow plug. Also set the meter to the lowest resistance setting available. Each should measure ~ 0.5 to 1.2 ohms.
If a reading is a lot less or a lot more then removal of the valve cover is necessary for further inspection. Once removed you can put the meter on each glow plug directly eliminating the wiring harness.
Old 12-16-2014, 07:40 AM
ProjectDually's Avatar
ProjectDually
ProjectDually is offline
Originally Posted by Diesel_Brad
At least with the FOMOCO ones if a harness goes bad you can replace just that ONE harness and not the whole assem
If you did the SD VCG's the same problem would be present as well. All one piece.
andym
04-19-2015 09:47 PM
majorgator
34
02-24-2015 12:18 AM
Reckless
38
12-11-2012 01:57 PM
89ford73
12-10-2010 09:32 PM
dirtworker
04-04-2008 09:20 PM
Quick Reply: Hard Cold Start with AE Logs
