Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
Old 12-13-2014, 07:55 PM
Zach Mahnesmith Zach Mahnesmith is offline
Zach Mahnesmith is starting off with a positive reputation.
Wet Spark Plug?
I had a misfire on cylinder 4 and I checked my coil an the boot was wet. Then I took my spark plug out and it smelled like coolant. It was soaked. What does that mean?
Old 12-14-2014, 07:52 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Often it means a leaking head gasket---have you yet done a cooling system leak down check?
Hope its not that serious though----tough luck if so.
Old 12-14-2014, 11:28 PM
Oil
Thanks for the reply. But I also checked another spark plug and it had oil on it. So I'm guessing you're right about the head gasket leak. My oil cap had white milky stuff on it but my dip stick looked fine.
Old 12-15-2014, 12:44 AM
RTSinDallas RTSinDallas is offline
RTSinDallas is starting off with a positive reputation.
I found water in the 1 and 5 cylinders on my wife's Mountaineer with a 4.6 3v. I had to replace both plugs because the corrosion was causing misfires. I wasn't sure if it got there from driving in the rain or if the head or intake gasket were leaking. We drove it for a road trip this weekend and it used some water, so looks like I'll be trying to track down a leak.
Old 12-15-2014, 08:10 AM
JWA's Avatar
JWA JWA is offline
Quote:
Originally Posted by Zach Mahnesmith View Post
T My oil cap had white milky stuff on it but my dip stick looked fine.
That's somewhat normal for those of us living in a 4 season climate. Humidity condenses on the cap and not enough heat during driving to drive it away. Since the dip stick looks good that's somewhat encouraging.
Is the coolant reservoir also clean, without any oily residue?
Similar Threads
Oil in Spark Plug Chamber jd1083 Super Duty & Heavy Duty 2 07-12-2011 01:13 AM
truck starts but sputters 1961ford Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 1 11-10-2008 01:55 AM
truck starts but sputters - TX 1961ford New Member Introductions 2 11-08-2008 08:34 PM
wet & black spark plug wdb1971 1987 - 1996 F150 & Larger F-Series Trucks 9 06-09-2005 07:37 AM
Compression readings jbondi Modular V8 (4.6L, 5.4L) 6 06-10-2004 04:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
