More questions on rebuild
on
Well damn I am an idtiot. I somehow got the wrong stock specs. Glad I started asking questions.
So I put in a lobe separation of 201-210 intake and 113-115 degree lobe separation and I got:
The comp 31-255-5
the crane 36391 http://www.summitracing.com/parts/cr...view/make/ford
the melling 24209 (link to it: http://www.summitracing.com/parts/me...view/make/ford )
and the Howards cam 212001:
http://www.summitracing.com/parts/hrs-212001-14
Here is the problem the only one that says computer compatible is the comp 31-255-5.
So will any of them work besides the 31-255-5?
I am going off post #5 in this thread by conaski:
https://www.ford-trucks.com/forums/8...ml#post7965689
The comp 31-255-5
You're making this far more difficult than it is (lol)
You can try any of those cams, they're all close in spec. The risk of poor idle quality isn't worth any of the gains you might see from running them. There won't be any power difference to speak of if you were to successfully run one of those other cams, they're all too close in spec and they're all "very mild"
Ehhh...yea and no. People have run larger duration cams on sd....some are successful, most are not. I thought about running something more aggressive, and I absolutely would have tried if I had built a stroker instead. Larger displacement engines are much more tolerant of radical cams, while still idling smooth and pulling good vacuum. Your little 302 is not going to tolerate much cam before idle begins to throb...and vacuum drops, which would confuse the sd system. Id be willing to bet money (if i were a bettin man) a speed density 400+ cubic inch stroker, or a 460, will tolerate cams the 302 and 351 will not.
Speed density isn't so bad. You can run a lot of mods with speed density and no tuning whatsoever. Virtually any change to maf and you're back on the rollers for another tuning session. I don't know what you're build plans are for the future, but 300+ hp 351 is pretty simple and dirt cheap with speed density. I haven't gotten a chance to dyno mine...I've been working on the rest of the truck and other projects. I will be getting onto the rollers, and I will be highly disappointed if I'm not handily over 300 at the crank, or 250+ at the wheels. Just food for thought.
crazy96863
15
02-24-2016 02:25 PM
bearster18
15
10-08-2007 09:13 PM
