Maybe found the new truck today... time for you to pick it apart
#48
#50
#51
#53
#55
#56
I wouldn't put all my faith in car fax either, they don't show everything and or all things.
I'm new here and to the Ex but not to trucks and cars and Fords. Ford all my life.
It's used, they don't make them anymore,I don't see where you can go wrong if it's mechanically sound,look at the truck and drive it and let the wife pick it, you're the one there..
The 5.4, 6.8 and the PSD 7.3 are great motors. I'd rather have the 6.8 in the ex and a diesel in a pickup or work truck. Good luck, nice looking Ex.
#57
Well, I don't know what price they're asking, so I'm without a little information. Edit: Now I see the price.
A few things, first being the battery is the wrong size. Only 610 cca and doesn't fit the battery box at all. That thing looks like it flops around a good bit.
Right rear tire suggests the front end is out of alignment. Notice that the inside of the tire is worn more than the outside.
Caked gunk around the grease zerks on the tie rods and ball joints suggest they haven't been touched in a while.
Hanging front license plate suggests lack of obscenities given.
Overall, it looks to me like maintenance was not a priority for the owner.
It will need tires sooner rather than later, and some front end work to fix the tire eating.
The defrost issue suggests a vacuum leak. Usually the ESOF system. Were you able to test the 4WD and hubs locking?
It really looks ill maintained in general. Air filter is toast and has been for a while. Engine bay hasn't been clean since it left the factory.
It's moderately rusty IMHO. Not beyond the point of no return, but in serious need of the "Christina" treatment.
You mentioned the power increase wasn't too dramatic over your 5.4. Is the truck overall nicer than yours? Interior better than yours or worse?
If it's all the same, then what are you gaining? 4WD and a bit more power?
It's 4K and I think it's safe to say it will need at least 2K and a fair amount of work put into it.
If you just wanted a run of the mill EX to drive for a while, then fine. You want to keep it for a long long time, so I'd be pickier.
You really need to see one from out west to appreciate the difference. This isn't the best picture, and it's definitely not an EX. 2003 Toyota from New Mexico. Anything brown you see is dust. Sure would be nicer to start with this.
#58
Just on that side. On the other side, the caliper is behind the wheel. I think they were like that for a short period of production. I recall having an issue finding the correct caliper for the left rear.
#59
#60
I still can't get over some of the rust found on those trucks back east. I guess you could say that I lucked out with mine, almost no rust anywhere, and it has spent a good chuck of its life in the salty air of the west coast of Oregon. Thankfully they do not salt the roads out here!
Here is a link to pics of the underside of mine to make you jealous.
I am still simply amazed that you would think that red Ex is nice when it comes down to rust.
