Not quite broke down in TX/AZ - map sensor???
Old 12-14-2014, 11:21 PM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,895 Likes on 1,145 Posts
Oh, I stole a map sensor off my buddy's truck today and everything seems normal again!!
Old 12-15-2014, 06:38 AM
petrokiller's Avatar
petrokiller
petrokiller is online now
Nice low mileage truck.
Glad the prob was easy fix.
Old 12-15-2014, 09:35 AM
SkySkiJason
Ok, not fixed... Driving with map unplugged again.
But nice sunrise in Bumble Bee this AM!!
Old 12-15-2014, 10:01 AM
clem1226's Avatar
clem1226
clem1226 is offline
This may or may not help, but I had the same problem with my truck a few years back...it ended up being the pin on the PCM that carries the MAP signal. When I attached the bulk head connector at the firewall to the PCM the pin got bent provideing an intemittant connection. I straightened it with a pair of needle nose pliers and all has been good.
Old 12-15-2014, 01:50 PM
SkySkiJason
Old 12-15-2014, 07:53 PM
BadDogKuzz's Avatar
BadDogKuzz
BadDogKuzz is offline
Originally Posted by SpringerPop
It's all internal to the little motor in the door lock actuators.
Same as the aluminum-foil "fix", but you tin-snip a penny to the same size as the varistor, and plug it in place of it.
See: https://www.ford-trucks.com/forums/4...cks-fixed.html
Just did the Turner and Will Rogers last month, and the tolls aren't all-that-bad. Unless, of course, you are spending NOTHING at all on fuel!
Pop
Thanks Pop Learned something new today and I love the fact that it costs no more then 1cent.
Jason good thing you are driving by yourself after the Del Taco.
Old 12-16-2014, 09:55 AM
SkySkiJason
Tim didn't mention the side effects of his recommendation...
Old 12-16-2014, 10:55 AM
SkySkiJason
Still no luck with MAP sensor problem. After some reading, it looks like I may have a wiring problem???
Any insight would be appreciated. I have today and tomorow to fix this problem - then I'll be paying a tech to fix it for my customer...
Feel free to call me if you have my number!!
Old 12-16-2014, 03:08 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Do you have the on-line access to wiring diagrams handy?
Pop
Old 12-16-2014, 04:35 PM
SkySkiJason
Pop
Not handy...
Old 12-16-2014, 07:47 PM
SpringerPop
Want it?
See attached for the one with the MAP sensor.
Pop
File Type: pdf
Old 12-16-2014, 08:07 PM
bigb56's Avatar
bigb56
bigb56 is offline
Is that PHX or Tucson?
  #28
Old 12-16-2014, 11:33 PM
SkySkiJason
Barstow, CA
  #29
Old 12-17-2014, 12:01 AM
gold7point3's Avatar
gold7point3
gold7point3 is offline
Did you check all of the intercooler boots to make sure they are tight?
  #30
Old 12-17-2014, 01:42 AM
SkySkiJason
So far a brand new MAP sensor appears to be working...
Test drive in the AM. After I change the clock spring and try to figure out why coolant temp on dash is wacky...
Quick Reply: Not quite broke down in TX/AZ - map sensor???
