How many ways... can you pull codes (Toni Braxton STAY OUT)
***I'm keeping this vague so it can be more help to the forum than just me***
Ok, I'm going to look at the red truck tomorrow and would like to know how many different ways there are to pull CEL codes/saved and stored codes. I would like to compile a list from the most basic of entering the actual Morse code from the CEL to the Ford code pullers in the shop. I'm personally asking because I have the ELM unit (Thanks ExxWhy!), a crappy $100 code reader from Vato-zone that's about 5 years old and an SCT tuner. Obviously 2 of those 3 will do the job, but what about the scanner? Should I bring it along? Since it's married to my truck will it do nothing on his? Will there be any benefit to bringing the scangauge AND the ELM unit? Should I just put the scangauge up in the free section or keep it in my "Rescue bag". What if anything should I really really be looking for? I would like to see a good list of things that I can re-write and make into a "How-to" of sorts that can be put into a sticky
Things I have already:
ELM unit and iPhone 5c running Dash Command
2 hands
Scan Gauge orange plastic block with 5 buttons 5000 modelXL turbo 3series
Some feet
SCT tuner (might not be relevant)
My ears to hear stuff with and say "Hey, this sounds like a diesel but it's a v-10... that thing's knocking like crazy. I'll pass!"
Thoughts guys?
2 hands
Some feet
Thoughts guys?
When buying a vehicle I always pull the codes and check the readiness monitors. I have come across several vehicles that have no check engine light but when I check the readiness monitors, none are complete. That indicates that the owner reset the codes recently and has not driven enough to trigger a check engine light for a given drive cycle.
Some vehicles will always have some readiness monitors incomplete, so don't just run away if you see one that is incomplete. Make sure catalyst and evap is done and you are usually good to go.
ELM and DashCommand should be good enough for what you want. That is typically what I use since it is compact and easy. It is a pretty basic truck so there isn't much to look at electronically.
What model did you buy?
This is what I use and it works great with the Torque app.
RioRand(TM) Bluetooth Mini Small Interface OBD2 Scanner Adapter TORQUE ANDROID: Amazon.ca: Cell Phones & Accessories
I'd post a pic but I can't seem to find the thing anywhere right now.
From what I've read online it seems to be very hit and miss with those elm adapters as to which car they'll work with 100%.
Thanks for the link, I might buy this one and see what happens.
On topic, Apoc how do you like your ScanGauge? Looking to pick up the SCII this week or next and am curious as to its performance. I know Razzi loves his SGII, reviews seem quite good as well. I just want something to monitor other parameters without having to throw more gauges and pods in the truck.
You can use a Paypal debit card linked directly and exclusively to your PP account... Amazon doesn't allow PP directly as its a former subsidiary of eBay, Amazon's biggest competitor. You can also check with the seller directly and see if they'll accept payment that way, it's worked for me in the past quite well.
SG2 with X guage- I received mine for Christmas and it works great. It runs 4 gauges at a time and can cycle through the others loaded on the fly. I have been using RPM, Trans temp, IAT's and water temp. Everything looks in range or where it should be. I had the voltage gauge on before the trans temp as the code for trans temp has to be loaded. That's also fairly simple with using there website which displays the codes needed and the book with fairly simple instructions.
You could also get a prepaid visa card with the amount needed for purchase. SG2 with X guage- I received mine for Christmas and it works great. It runs 4 gauges at a time and can cycle through the others loaded on the fly. I have been using RPM, Trans temp, IAT's and water temp. Everything looks in range or where it should be. I had the voltage gauge on before the trans temp as the code for trans temp has to be loaded. That's also fairly simple with using there website which displays the codes needed and the book with fairly simple instructions.
I've been all over their website. Can't wait to actually get the unit!
