F1 Door removal help
If your body is painted you can try a couple easy things but you should be prepared to remove the hinge(s) so you don't damage the rest of the door. You will have to drill out the rivets on the door side of the hinge and replace them with shallow button headed allen or torx bolts. I can give you a source if you can't find one.
tomrflorida
02-22-2015 12:52 PM
sancochojoe
02-01-2004 10:11 AM
irondragon79
06-19-2002 02:39 AM
