Need alignment, but axles bent?
Hello. I have a 1985 F350 2x4. I took it to the shop to get a front end alignment, and they said it couldn't be done because my front axles were bent (left & right). The shop said I needed to have the axles straightened. I live in Delaware, and tried calling everywhere. Nobody does it. I've also tried to find buy the part/parts new, but I can't find it anywhere. Any ideas?
Yeah. Last shop I knew that did it sold when the owner finally retired about 5 years ago. He was 85 or 86 and had been doing alignments since he was 17. He had pictures aligning model A's as a kid hanging on the wall. Really cool guy to talk to, and lots of the old rodders and antique guys used to go there.
The bigger shop should have a rack they put it on with a spot to put chains and a very large jack. They chain it down in the right spot and then use the jack to push up and bend it. They may not have the specs for your smaller truck, so you might have to volunteer to go beg for them from a smaller shop, and then run back to the bigger shop and give them the specs(caster, camber, toe, etc.)
I found I had one bent axle a year or so ago......but the springs were also original, & had sagged over time.
I replaced the coils (which made a significant improvement alone to the steering) then straightened the bent axle, with a chain & large hydraulic jack, to match the undamaged one.
Before this repair the steering had been slightly unstable in a straight line (best way I can describe it), despite everything being tight - but is good now.
pwjackson42
06-24-2014 02:43 PM
