C6 behind a 300/6 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
C6 behind a 300/6
Old 12-11-2014, 11:33 PM
Bulldawg1081 Bulldawg1081 is offline
Bulldawg1081 is starting off with a positive reputation.
C6 behind a 300/6
I've contemplated putting a c6 in place of my t18 but I keep hearing the horror stories of it really making the 300 feel REALLY sluggish, so I wanted to see if any of you had that set up and what you thought about it?
Old 12-12-2014, 12:32 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
A stock C6 no, a built C6 with the proper TC and so forth may be ok. Heck a built AOD would be ok as well and you would gain Overdrive.
Old 12-12-2014, 06:16 PM
It was just an idea, I've always liked the c6 so I figured I'd ask.. Thankyou!
Old 12-23-2014, 07:50 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
As a huge 300 six fan I personally would never have an automatic behind one. There is a noticeable amount of parasitic power loss going from a manual to an automatic with these engines. The powerband is so short on these engines (like a diesel), they're all done making power by the time the automatic starts doing anything. You could probably help things out by regearing the axles, not sure if it would be worth the time and money.
Old 12-23-2014, 08:51 PM
Matt Mariani's Avatar
Matt Mariani Matt Mariani is offline
Matt Mariani is starting off with a positive reputation.
I think a well maintained 300 6 could run indefinitely.
Old 12-23-2014, 09:07 PM
Pkupman82's Avatar
I have two 300 six powered F150s with well over 200k on the clock. Those things don't die, one of my favorite engines of all time!
Old 12-23-2014, 10:27 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
I'll chime in and say "DITTO" to everything already mentioned about the 300! You want to have some real fun, drop a ZF behind a 300.
Old 12-24-2014, 09:38 AM
Pkupman82's Avatar
I swapped a ZF into my 96 F150 as part of the 4x4 conversion. A ZF/300 combo coupled with 3.55 gears is the perfect combination.
300 six to replace 351m?? saltbranch Ford Inline Six, 200, 250, 4.9L / 300 3 05-12-2016 11:59 PM
300 in a Super Cab? 79SPRCAB 1973 - 1979 F-100 & Larger F-Series Trucks 30 01-26-2014 05:28 AM
will a c6 transmission bolt up? 360F100 Ford Inline Six, 200, 250, 4.9L / 300 2 01-15-2012 05:11 PM
Can you put a 2 barrel carb on 300 6 John 300 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 10-13-2009 08:36 PM
300 I-6 rogwelch 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-13-2000 12:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
