E4OD down? or electrical?
Hey all, I currently have a 1995 f250 hd with an e40d. had the truck for just under a year. maintained well and has run great. However, the trans has started shifting REALLY hard.... it acts like it doesn't want to shift at all until about 2500+ rpms and then slams into the next gear unless I pump the pedal right before a shift point. Trans just on its way out or is there possibly an electrical problem these trucks tend to have? No O/d flashing. Also I am unfortunately unaware of the trucks history or trans history of work but the truck does have 253,xxx miles. thanks for any info on how these trans actually choose their shift points or any diag help.
Definitely check for codes, as Mark suggested. I've had similar issues with, and without, the OD light flashing. Most times it has been a bad or dirty Vehicle Speed Sensor (VSS) in the rear differential.
I've had some luck removing the VSS, wiping off the "crud" and reinstalling. DO NOT USE ANY CLEANERS, just wipe it off with a shop rag or paper towel. I ohms tested my old one and it returned a reading of 1985 ohms. I tested the new one, too, even though it was the wrong part. The new one tested at 480 ohms.
If your VSS is more than a few years old, or you're not sure how old it is, replacing it is cheap insurance. The part is less than $30, at least it is in my area. I have another one on order now, and am waiting for it to arrive. I received the wrong one. I have an electric odometer, and the VSS was for use with a mechanical odometer. I wasn't aware there was a difference between the VSS models available, but once I opened the box, I could tell right away it wasn't the correct part for my truck.
If cleaning the VSS didn't fix the problem, I'd replace it. You might want to check your wiring and connector, too.
Where would this barometric sensor be located? Little up date I installed the shift kit which seem to improve it but still had very rough shifts. Then had a CEL show up tried to read codes got a no communication from the scanner, but i figured this was because my scanner didn't speak powerstroke. Started the truck up drove 20 ft it died and wouldn't start back seemed like it wasn't getting fuel ! Finally got it to start and limp it home. did some digging and found the truck has had a cab swap done (poorly swapped I might add!) Any who decided I was going to double check their work and began with tearing out the dash and checking the interior harness. I found several poorly connected connectors and a set of very loose grounds! Also found four wires coming off the main harness cut and zip tied up?? No idea what they go to as I didn't see any other connectors missing. Obviously going to replace the harness and make sure all connectors are good! but I'm curious as to where that baro pressure sensor is located now?
The baro is up above your right knee, so I've been told. I could never find mine though.
Its a little black box attached to the column, looks like a relay. and from the trucks I have seen its been on the left
If you have anyone you know with a 7.3 ask if you could swap it out and try it rather than buy another one bc they are kinda pricey
relentlessmx
12-20-2008 02:14 PM
TRKR_MAN
03-03-2004 11:10 AM
