Blower motor runs without key
Old 12-11-2014, 09:32 PM
BigWhite76's Avatar
BigWhite76
BigWhite76 is offline
Strange goings on with my 76 CS w/factory air. Without the key in the ignition, if I move the heater lever to Defrost, I can hear the blower motor. Moving the fan lever to full gives me full flow. Now, if I put the key in and move it to the on position, the blower motor quits. Kind of frustrating when your window is fogged up.
Should I look at the ignition switch first or the blower motor?
Thanks
Bob
Old 12-11-2014, 09:55 PM
dlburch's Avatar
dlburch
dlburch is online now
do the wipers work without the key in the ignition? Radio?
when you turn the key on to run (making the heater fan quit) do the wipers/radio work then? what happens when you turn the key to accessory?
Old 12-13-2014, 11:50 AM
BigWhite76's Avatar
BigWhite76
Without a key, nothing works except the blower motor in the Defrost position.
Accessory or On positions kill the blower but energizes everything that should be energized.
Bob
Old 12-13-2014, 01:08 PM
4x4slik's Avatar
4x4slik
4x4slik is offline
Not an electrical expert, but sounds like maybe the motor is wired wrong. Sounds like you have a always on power source to the hot on the blower, and the ground is tied to the ignition power. When it is off, the ignition power is making a ground, causing the motor to run, when the ignition is on, it puts power on that ground. Would think something would blow, but I could be way off on my idea.
Old 12-13-2014, 05:08 PM
dlburch's Avatar
dlburch
'76 with factory air has a blower motor relay (behind the dash I believe). It will be connected between the AC mode switch and the blower speed switch with three wires, Yellow w/red, Orange, and red w/black.
with they key off, check the voltage on the Yellow with red stripe wire. That is the wire that should energize the relay and apply power to the blower speed switch input.
Did this ever work correctly? the symptoms you describe would happen if the relay was replaced with a normally closed instead of normally open relay.
Old 12-14-2014, 10:39 AM
BigWhite76's Avatar
BigWhite76
Update:
Seems the blower will run without key in any heater lever position except 'Off'.
(Runs in A/C, Hi/Lo, Heat, Defrost)
Blower motor sounds like junk when I just tried it.
Need to replace the heater core so I'll be adding a blower motor also. Would be nice to find this gremlin prior to installing new blower as an install test would have failed and I would have blamed the new blower.
I'll pick up a volt meter and start probing.
Under the dash I go !
Thanks,
Bob
Old 01-19-2015, 05:21 PM
BigWhite76's Avatar
BigWhite76
After digging my truck out of 2' of snow, I pulled it into the garage and attacked my blower motor problem. I found the relay you mentioned but I have no way of knowing if it's normally open or normally closed. Here's the specs on it (pic).
Is there an online reference for the code numbers on this relay? I've checked wiring diagrams but see nothing with these code numbers.
Thanks
Bob
Old 01-19-2015, 06:14 PM
dlburch's Avatar
dlburch
I think that is the correct relay. What was the voltage on the wire I mentioned...I would check it both with the key on and the key off. I assume the blower stops when you unplug the relay?
Old 01-20-2015, 09:15 PM
BigWhite76's Avatar
BigWhite76
dlburch
Misplaced my multimeter a while ago so I have to hit the parts store for a new one.
The blower definitely quits when I unplug the relay.
I'll post my results with the multimeter after I hit the parts store.
Thanks for your continuous help.
Bob
Old 01-23-2015, 05:03 PM
BigWhite76's Avatar
BigWhite76
The source of my problem with the blower fan was the relay.
PO had it mounted without a good clean base for ground (paint free).
I sanded a spot under the dash to bare metal, mounted the new relay and everything works according to Henry Ford.
Thanks for all the help...you guys are alright
Bob
Old 01-29-2015, 10:53 AM
bkaul's Avatar
bkaul
bkaul is offline
If it's working but just noisy, it might just be leaves/debris built up in the housing that you can clean out when you change the heater core without having to replace the motor.
Old 01-29-2015, 11:09 AM
BigWhite76's Avatar
BigWhite76
I was able to pull the heater motor with squirrel cage still attached. I removed one bolt holding the dash at the lower right corner. Pull the bottom of the dash out while you swing the evap up and it gives you more space.
Old 07-22-2019, 10:06 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Is there an online reference for the code numbers on this relay? I've checked wiring diagrams but see nothing with this ID engineering number.
D2LY-14512-A .. Safety Relay / Marked: D2LB-14C690-AA .. D5AB-14C690-AA or BA or CA / Obsolete
Misc. applications: 1975/79 F100/350 & 1978/79 Bronco with factory A/C // 1975/79 Econoline with trailer tow package // 1977/78 LTD with power windows // 1977/80 Granada/Monarch with sun roof.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 27 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 34 = 800-543-4959.
Mustangking1
01-24-2017 09:15 PM
Firefighter 1406
01-02-2014 08:09 PM
jeffdoerr
1999 to 2016 Super Duty
07-22-2009 09:01 PM
stuland
08-26-2001 09:48 PM
Quick Reply: Blower motor runs without key
