Excursion Running Boards vs Step Bars
On the step bars, 3 brackets are used to attach the bar to the truck. 10 bolts in total. On the running board, there are 5 mounting brackets which would yield 18 bolts. On the running boards, are all the brackets attached or did they only attach 3 of the 5 brackets similar to the step bars? Reason I ask is I haven't enough hardware to attach all 5 and am curious if attaching only 3 would be safe like with the step bars.
I'm happy enough to order the hardware but if your folks' board's brackets aren't all attached I wasn't going to go the extra mile either.
Okay I see what they did. On each of the 5 brackets, they have 2 bolts anchoring it to the truck. On the step bars, there are only 3 brackets and they have 4 bolts anchoring each bracket instead of 2. I think I will mirror yours and use 2 bolts each instead of 4 bolts on each of the 5 brackets. 4 bolts over 5 brackets might be overkill. I'm swapping mine to stainless as well and they aren't all that cheap.
Thanks again for crawling under there. (nice and clean too!)
All done, thanks for the help!
I had to hacksaw 6 of the old bolts off. They were pretty rusted. So I replaced them all with stainless steel. I ended up using 4 bolts per bracket instead of 2. That way my OCD would let me sleep instead of knowing I had two wholes not being used per bracket. Thanks again.
Yea you gotta love a Texas truck. But alas, Texas can't full credit here. This truck belonged to a couple in OR that also had a house in Cabo. It spent a bunch of time south of the border so there's a ton of sand lurking in it's nooks and crannies. It's only been in TX a couple of years.
Juan, do you think I could pry another favor out of you? My running boards have 2 feet of loom wiring coming off of them and end at a connector. I guess I just assumed where they needed to plug into would be in the vicinity of the running board. I can't find a harness or anything where the running boards should plug into for the lights to work. Are you able to take a picture of where you boards connect to the trucks harness? I'm guess they connect to a connector that runs over to the main harness on the frame.
