A couple of 7.3 PSD questions.
I recently purchased a 1995 F250 Powerstroke. I am noticing, however, that it has a couple of issues.
I fired it up the other day, my check engine light kicked on, and the engine began to idle very, very roughly. I shut it down almost instantly, being concerned about damage. I did some research, and found that it sounded like the problem was the ICP sensor. I unplugged it, and found that the connection was essentially stuffed full of oil. The engine is running fine without it connected. Is it safe for me to drive the pickup without it connected until I can a new ICP?
Secondly, I have noticed a small pool of coolant in a valley under the turbo. I haven't got even a faint idea where it could be from, and I've spent a fair bit of time looking. Any guesses?
Thank you.
~Christopher.
Thank you.
~Christopher.
Take a sample and get a ph test on it. One for diesel ph and the other for coolant. Or you could always taste it, coolant will taste kind of sweet, just spit it out and wash it out with water. My mechanic buddy taught that one. If it's diesel, you'll know.
The only thing I can think of is maybe your heater core lines are leaking, that's the only thing that goes over that area coolant wise I can think of.
Honestly that's what I would lean towards, it being fuel puddled up there.
Quick update- I fired the pickup up again. The ICP was disconnected still, and it fired up with the rough idle. I shut it off, and restarted it, and it was fine. The engine shakes really heavily. Could this have an additional problem, or is that normal to have happen on startup when the ICP is out?
dalestotlar
07-04-2013 09:38 AM
