Seats for my 54 ford pick up
I need a pair of bucket seats for my truck an am not sure which ones to use. I found a pair of buckets that I thought would work on craigs list for 40 bucks I soon realized they would be more work that to just buy a better set. That being said I would appreciate any suggestions as to what kind of seats would work best. I liked the bench I had but would not work for me because I have just put a T-5 behind my 302 and it wont work with the T-5. I need some with a flat mounting surface and a narrow back any help would be greatly appreciated.
bill
bill
looks great, I'm in the process of doing something similar and have been looking for armrests. did you make yours or what are they from.
thanks
mike
I recently junked my 98 Windstar and took the seats out to use in my 48. The mounting points are level but the headrest is a little high, obscures some of the back window. But they should be an easy install with few mods. Gonna have to relocate the fuel tank though. Might use them in my 92 instead. You could probably pick a pair up for cheap from a JY.
Received 4,119 Likes
on
on
Mike
on
I started this project back in April, I've only worked on the cab this far and putting it in primer now, I sprayed the epoxy primer yesterday and filled all the seams today. I plan on getting it in high build tomorrow if my back holds out. The cab was in pretty ruff shape, pics are in a gallery. https://www.ford-trucks.com/user_gal...&albumid=44929
This is what I started with
This is it now. I've been meaning to start a build thread and may sometime over the winter.
