55mph turning 4000rpms?
Old 12-20-2014, 05:39 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,592 Likes on 1,297 Posts
4032 RPM at 60 mph with 30 inch tires requires a 6:1 axle ratio.
If you are in low range (1.96?) with 30 inch tires and 3.50 axles, you will turn 4610 RPM at 60 mph.
Old 12-20-2014, 10:30 PM
nlassley's Avatar
nlassley
nlassley is offline
That would be a 7.14 ratio if he's turning 4k at 55, it not unheard of for tachs to read normal at idle and show rpms way higher than what the engine is actually turning.
Old 01-03-2015, 02:27 PM
GaRedneck91's Avatar
GaRedneck91
GaRedneck91 is offline
Alright guys don't give me to hard of a time. I took the casing off of my Tach and there was a little switch there on the number 6, haha. I'm guessing now that it's on 8 it will probably read around the right rpms. I didn't know the switch was on the inside of the TACH.
Old 01-03-2015, 03:14 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
No reason to feel bad about it, you aren't the first or last person to find out about the switch so I doubt anyone will give you a hard time..
Old 01-03-2015, 11:22 PM
rockittsled's Avatar
rockittsled
rockittsled is offline
Alright guys don't give me to hard of a time..
NO SOUP FOR YOU!!
Glad you got that solved. Glad we could help.
Old 01-04-2015, 02:05 PM
nlassley's Avatar
nlassley
nlassley is offline
We've all had it happen. Lol.
Old 01-14-2015, 08:44 AM
critterf1's Avatar
critterf1
critterf1 is offline
What does it read now?
Old 01-14-2015, 09:17 AM
LedheadELH's Avatar
LedheadELH
LedheadELH is offline
With 33s and 3.50 gears in 4th gear 2,000rpm will be about 50mph. I ran this truck for years with no speedo and had 33s.1,500 rpm was about 40 and 1,000rpm was like 27mph.
The same truck with 4.10s and 33s 3,000 was roughly 60. 2,000rpm was about 40mph
Same truck still with 4.10s and 37s. 2,200rpm was 60mph.
This was all by factory tach and using those radar signs on the side of the road, all in 4th gear on a NP435 so 1:1.
CMMC
1983 - 2012 Ranger & B-Series
01-25-2012 06:58 AM
greywynd
04-04-2010 06:34 AM
gotjeepzj
08-12-2009 07:24 PM
fordeverpower
22
09-05-2003 08:48 PM
Idaho
08-20-2002 02:28 PM
Quick Reply: 55mph turning 4000rpms?
