F-550 Seat replace/ airbag light
Hi Everyone,
New to the forum here. I bought an 09 F550 (XL, 6.8 v10) cab/chassis flatbed w from an auction in Canada. Got a great deal, but it definitely needed some cleaning up. Luckily, there is a Ford truck dismantler nearby, and I was able to get some new interior/ dash parts and replace the ripped up bench seat with a nice cloth 40/20/40 seat. When I got everything connected, I noticed the airbag light will not go off. Tried turning the passenger airbag key switch to off, nothing.
If anyone has any advice/wisdom they could pass on, I'd really appreciate it!
Thanks,
Steve
Thanks,
Steve
did you have any connectors under the seat that you didn't hook back up when i swapped my seats I had to use the seatbelt receptacle or whatever the thing you put the buckle in is called from my old seats because the plugs on the connectors didn't match and if you left it unpluged the air bag light would go nuts
My seatbelt receptical had a connector wired to them that plugged in to a connector that came out of the carpet that didn't match the ones that were on the seats I got that's why I changed them to my originals but it sounds like you used your orginals any way so I don't think swapping them is going to help you in this case. If you only had one connector under you seats and it plugged in ok I would go back and check that connector and see if maybe one side had a few more wires than the other and that maybe where you light is coming from even though the connectors fit together. You could also take it and have the codes read for the air bag system that should tell you where exactly your issue is coming from.
ketel0ne
1999 to 2016 Super Duty
04-15-2014 09:10 PM
ledbetter
06-02-2005 09:00 PM
