Winter with the old diesel- help
Received 3,107 Likes
on
on
There is no downside of slapping on a new filter. They are a spin-on unit...look like a short oil filter on top of the motor.
I'd buy whatever brand you are comfortable with. They run 15 to 45 bucks...pays to shop around. I always check ebay and Amazon, too. FWIW, I generally buy Fleetgard and generally avoid Fram.
Here is a description:
https://www.ford-trucks.com/forums/2...hange-how.html
Roy
Roy
There are a few different options for the filters. The original ones that came with the truck had a removable bottom that collected any water that came through the fuel line. This bottom piece also had a water drain valve and a water in fuel sensor. One piece filters are available that do away with the removable bottom piece. They can be had with or without a port to screw in the water in fuel sensor.
I use Wix 33617 filters. They include the port the water in fuel sensor screws into and a water drain at the bottom. You should be able to cross-reference that in any auto store if they don't carry Wix filters. They can be found cheaper online if you have the time to order them.
Also do a search on the forum for "air intrusion".
And, a search for fuel heater "O" ring replacement.
A very slight leak at the wiring for the fuel heater can allow an air pocket in the fuel filter. (where the fuel leaks out, air leaks in..)
The symptoms of "air intrusion" are;
After cranking a cold engine, the engine will run. Then stall, and be VERY HARD to crank again.
If the batteries and starter are not in TOP condition, you will have trouble getting it to rune a second time.
fuel heater is on the stock seperator on a 6.9 on the firewall everyone bypasses them junkers.
#28
The OP has a 94, so it would have a 7.3 with the fuel filter that has a water separator built in. Thus it would have the fuel heater in the filterhead which is mounted above the engine, nothing on the firewall.
#29
#30
The filter's not, the thread is different, but you could swap out the entire filter head, but then you're more leak prone than before with the built in fuel leaker (heater), the stupid spin on bowl on the bottom, and the various sensors that are not present on the 6.9 head.
