94 f150 4.9l engine noise
I have a 1994 f150 2x4 ext. cab short bed w/ the 4.9l. it was manufactured 12/93 if that means anything to anyone. there is a noise coming from the engine when it is under load, i want to say its a knocking noise but its not quite, almost a diesely noise. it is not present when cruising, you have to be accelerating or under load, sometimes you are able to hear it at idle but barely. my guess is that it might be a collapsed hydraulic lifter or a small chance its an exhaust leak although i doubt it. i have a video which you can hear it if you have good speakers or headphones.
exhaust leak is more probable that what you think, a inline six is longer than a v8 or v10 which makes it more prone to warping. Another thing it could be is your timing gear, these are known to be noisy and make a sound like you are describing. i didnt hear much in the video but could be my headphones or computer, it could also be any of the above mentions as well.
could check your timing.
Spark knock? Didn't listen/watch video but your description is typical spark knock. Slight noise at idle could be a secondary noise.
JohnOsky
07-27-2010 06:32 PM
Rat wagon
16
08-07-2003 11:45 PM
