Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Old 12-11-2014, 12:07 AM
69issofine 69issofine is offline
69issofine is starting off with a positive reputation.
3.8 liter
is the parts off of a fwd 3.8 the same or are they different just trying to explore all my options.
Old 12-17-2014, 09:44 PM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
While some parts may interchange, the blocks are clearly cast with the FWD or RWD lettering right on the blocks. There are also some exterior parts, such as the water pump and water pump pulley, that are different.
I know because I have a '95 Mustang with the 3.8 and a '97 Thunderbird with the 3.8 and I've tried to replace lots of discontinued RWD parts with FWD parts and they don't mix. My advice is to keep looking for RWD parts to put in your RWD vehicle.
Old 12-19-2014, 02:09 AM
3.8 liter
i have a 95 windstar with a 3.8 liter engine and was wondering if a camshaft out of a rwd engine will fit ? my engine has roller lifters and there is a little rust on the cam lobes with a bit of pitting. where would be a good place to buy a new or reground one. would i need new lifters and pushrods,and rocker arms to? i am trying to go low budget. would used ones from the wrecking yard work or is that to redneck.
Old 12-19-2014, 09:25 PM
Well, I picked a year out of random (95), and it shows that the RWD and the FWD Ford cars use the same camshaft. I would have no problem reusing the roller lifters either, but would probably run them on the exact same cylinder that they were pulled out of.
Similar Threads
9 3/8 rear end ? gary534 Clutch, Transmission, Differential, Axle & Transfer Case 3 07-01-2006 05:34 PM
3.0 to 3.8 67blueford Engine Swaps 1 05-27-2006 10:59 PM
What all will the 3.8 fit? jasonj79 3.8 & 4.2L V6 2 02-07-2006 07:53 AM
4.2 and a 3.8 f100guy 3.8 & 4.2L V6 3 01-14-2004 07:30 PM
Who knows about the 3.8l? CACWBY 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 6 01-23-2003 10:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
