Eratic Blinkers
Eratic Blinkers
I have a 2003 Explorer Centennial and recently both blinkers would blink anywhere from 1 - 6 times and will turn off. Both sides. Flashers work fine. Lights work fine. I changed the MFS (guessing here but I have 224,000 miles on it). Blinkers worked fine the first few times then went back to the same problem. Will the flashers cause this? I do hear a very fast double click sometimes and have heard a buzz on a few occasions.
I appreciate any input you have.
The flasher does seem like a reasonable suspect. I'd also suggest you inspect the wiring the steering column for evidence of damage, particularly at any connectors. Others have found that the harness seems to be a tad bit too short and gets strained from the tilt steering wheel. Some have had troubleshooting success by changing the tilt position of the steering wheel and finding the symptoms go away. That's a pretty quick thing to try that might yield a very good clue as the the problem.
-Rod
-Rod
hiflyin
Electrical Systems/Wiring
04-30-2013 06:27 AM
dad2bandm
02-08-2012 10:11 PM
tkloppel
10-27-2011 06:18 PM
