Trans wont shift out of first till 3000 rpms
I have a 93 f250 4x4 with the 7.3 idi non turbo that wont shift out of first till its over 3000 rpms. I read the sticky on the tps adjustment and have it set at 1.2 at idle and I could only get it to go to 3.8 at WOT. The truck shifted perfectly before I put it in 4lo, then it got stuck in 4lo. I was able to get it back into 2wd, but I still cant seem to get it out of first till over 3k. I just put a new TPS on and adjusted it to the above readings. Any help would be greatly appreciated.
on
oh wow.interesting.so you need to suspect the sensor in the t-case.it's just a basic little bugger that tells the trans if your in 4lo or not.you can't miss it.the only electrical plug there.inspect the plug/wires and if ok,pull the sensor.replace if needed it has a little ball on it.it might be frozen up.see if you can free it up.
you should grease up your 4wd linkage every year or two and shift it once a month to keep her shifting smooth.might want to check/flush the fluid while your here.it's a couple quarts of ATF.
tip; a gear lube cap screws right onto an atf bottle for easy access/pour for the fill hole.
im leaning more that way myself, I checked the VSS(cleaned and re-installed), the electrical connector where the shift cable goes, all the relays. Im kinda at a loss... I think im going to change the transfercase sensor and see what happens. I also dont know what that sensor is called.
on
im at a total loss as well brother.the problem happened exactly at the time your t-case was shifted and got stuck.it's got to be related to that switch/connection.maybe you'll see the clip that goes on the sensor is screwy or something.it's making the 4wd indicator function properly though.keep us posted.very interesting.
are there any codes?
ebaldwin89
17
02-27-2018 12:22 PM
turbotech
06-20-2017 07:05 PM
