&#$&*(@$( On the side of the &(%$^%$& road again
Just driving to Dallas marveling at how well my truck is running, pulling a light load, 2500lbs, and then it starts sounding funny, can't really describe it except that I thought it was tire-related, which is usually just the highway. so straining to look in my side mirrors at tires and see smoke. Thought I had a wheel bearing about to blow, but as I slow down, I see its the exhaust. I got lots of smoke coming out.
It's light gray at idle, and my guess is it smells like oil. On the highway, it looked darker coming out of my exhaust at 65mph.
Not running hot, I just changed the oil this morning, and still seems to have plenty and can't tell that it's lost any. Motorcraft filter from Walmart. I get codes P0106, p0672, and p0401. The EGR delete always throws one of those, and I have a glow plug out. I've had the other a while and maybe since then, I don't know. It's been running great, so I hadn't messed with it.
I haven't tried to race it, since I had a small trailer, but it doesn't seem to be running badly. I've just dropped off the trailer and am sitting in the parking lot not sure what to do next. Am I about to blow this thing up? Did it actually already blow up, and all that smoke is the result? Maybe blown rings or a hole in my piston or something terrible? Got my Scan Gauge. I'll post all the readings next.
Here's where I look bad again.
My scanguage still doesn't show any IPC Voltage. Recall it didn't when I last got back running. Again, it's been running great so I figured it has to be either SG or user error. I know, I should have figured out why. Could that cause any problems? Ditto with it still showing IPR of 32 at warm idle. Didn't really get any suggestions from anyone here why it would be doing that, and otherwise seemed to be running fine, so I didn't mess with it.
My EOT/ECT delta has been great. Last trip, I was pulling 14000 over hundreds of hilly miles, it only got close to 15 once and was usually less than 10. The 200 miles I drove today before the smoke, it was always low, and is now.
KOEO/at warm idle from Scan Guage:
IA2 155 129
CVI 5.00 5.00
EBP 14.7 17.4
IPR 14.8 33.2
SYC 0 1
FLP 12.0 13.0
FMP 47.5 48.0
ICP 0 875
VLT 12.2 13.2
IA 143 85
IA2 155 129
CVI 5.00 5.00
EBP 14.7 17.4
IPR 14.8 33.2
SYC 0 1
FLP 12.0 13.0
FMP 47.5 48.0
ICP 0 875
VLT 12.2 13.2
IA 143 85
Just driving to Dallas marveling at how well my truck is running, pulling a light load, 2500lbs, and then it starts sounding funny, can't really describe it except that I thought it was tire-related, which is usually just the highway. But, I look strain to see in my side mirrors, I see smoke. Thought I had a bearing about to blow, but as I slow down, I see its the exhaust. I got lots of smoke coming out.
Yeah, I thought about the turbo. My last posts described a loud noise it would make under the highest load that I assumed by the high-rpm spinning sound was either the turbo or fan clutch. And that my SG Boost number never gets above 20 no matter how much I push it. After talking to others here and based on the Ford tech telling me my fan clutch was getting weak, I decided it was that and after not having any more problem with it for a few thousand miles, did nothing.
Now I wonder if it wasn't really the turbo. How hard are seals to put in? Any special tools required?
